Bike as 25000 miles and only 1500 on a topend.It sat for 6mo and when started runs great but pukes oil from crankcase into the breather.Anyone know what is wrong.
your motor is sumping, or allowing extra oil into the crankcase as it sits. It is common
enough and a search should find on of the previous threads on the subject.
What is needed is to reseat the check ball in the tappet screen.
Like Fxr says, it's pretty common..
It happens to me once in awhile if, after swapping motors, I let a motor sit a wee too long before slipping it in to another sickle..
Doesn't occur every time however..
After it is done pumping out the oil that seeped past the check-ball it will usually not do it anymore..
Don't need to re-seat anything, it'll re-seat all by itself..
The next time it sits for a looong time it may Not do it..
It simply doesn't happen every time..
Soo, you know,, the next time it might seal up perfect and there'll be No sumping,, luck a the draw..
