1 - 20 of 20 Posts
My dealer is having a winter special. They will install a 1550 big bore kit for $499 including all parts and labor(and free pickup/drop off and free dyno run) . This price does not include the heavy duty clutch Spring. I already have the high flow SE air filter and map download on my 2002 FLHRCI. Do I really need the clutch spring? Just curious since it is listed as part of the stage 1 kit package in the catalog. I'm wondering what the pros/cons of spending the extra cash would be. I have to draw the line on expenses somewhere or it will never end.
Thanks for any feedback
Infidel
dfs14580,
MSRP on the big bore kit for EFI FLTs is $960. If you can get parts and labor for $500 bucks, WTF are you worrying about a few extra bucks for the clutch spring for?
Even if the fucken spring costs a couple hundred dollars you're still getting a sweet deal.
wyo
The performance clutch spring p/n 17048-98 is integral to the 1550 update and should be installed with the stock clutch. It is $20
The performance clutch kit p/n 37952-98A is not. It is $180.
Infidel
I didn't mean to imply that the clutch spring cost $200. Only that getting a 1550 BB kit installed for about half of the msrp of the parts alone was a great deal. And no matter what the cost of the clutch spring, its STILL a great deal. If the dealer is reputable, I jump at that offer.
regards,
wyo
regards,
wyo
Yea man !!!...
I ain't buying it.
Are you sure he isn't quoting you a LABOR price of $499? Now that might sound reasonable.
As far as the heavier clutch spring goes, some folks been running high horsepower engines usning the standard come-from-the-factory clutch, others beef it up, others go to a whole new super-duper clutch set up of some kind. All depends on how you ride, I'm guessing.
If you want to save some labor $, tell the dealer you will install the heavier clutch spring yourself. $20 for the spring and about the same for a new primary cover gasket will get you through this - it's an easy install.
I don't think I added a different clutch spring with my stage 2 kit, unless the dealer just "threw it in" which I doubt. I have 7k miles since the stage2 w/ no problems, but I am not real hard on the clutch anyway.
Is this something i should ask to have installed at the 20K service? Any guess as to how much labor might cost?
Barnett has a cool upgrade much better than the diaphram spring. You use you stock basket but the outer hub is there own and it has 6 springs that are tunable. It looks like the scorpion but not as pricey and will hold most hot street motors. I think that last one I put in had 3 set of springs.
Discussion Starter · #11 ·
Thanks for the replies. Sounds like I should go for it even though the clutch install isn't on sale. With the 1550 I'll probably ride harder by instinct so maybe they'll work a deal on that too. I'm watching expenses because it is a spontaneous decision to do this now(VISA). The parts alone would be about $500 --not $900(no cam). But still a pretty good deal--and YES Everything -parts and labor for $499. The clutch Spring would add the price of the part, gasket and labor. I could do later, or have it done now. I won't do it myself--it's 25 degrees in my garage.
Discussion Starter · #12 ·
As a follow up, I'd like to add that the $499 didn't include the ECM calibration which was an additional $150. But I still had it done, and everything went well. The original cylinders are bored out to 95 at a race shop--which probably allows them a little breathing room on the cost vs buying them. All and all, it was still a good deal. Anyone who wants to visit freezing NY where the cycle business slows in the winter can take advantage of this opportunity for another month. See you in Milwaukee.
Had the heads ported and polished on our low rider, high compression pistons, SE257cams, V&H pipes, new 44 carb Mikunie, Dynoed at 98tq and 92hp. Problem is, its my wifes bike, My SE Roadglide stage III cant touch it. View from behind is great!
A white bros ramp in the trap door will help on clutch pull effort it so desired. Cost is less than $30 easy install. The ramp reduce's effort by 40% or so.
I just had the stage 1 BB kit installed, clutch spring and all. I paid $422.50 just for labor at the dealer. Sounds like you are getting a "back door" arrangement, so far you won't be getting the recalibration and the clutch spring. Are they going to reuse your gaskets too? I don't think I would do it, something sounds not right. There is a definite harder pull on the clutch lever, nothing serious but bad for parades! I may look into the ramp that HDWrench is talking about. Gotta break it in again for 200 miles now.
It's broke in and I got on her today to see what changed. Higher revs and I could tell the ease of passing without having to downshift. I am happy with the upgrade, even though it was kinda pricey!
1 - 20 of 20 Posts
