Sounds good. How much?TOMPAGLIA2 said:
I'll bet for the same $$$ you could go with a JIMS 120 in motor or an
Sounds good. How much?TOMPAGLIA2 said:Anyone familiar with the SE 113 ci upgrade. Pro"s & cons for 06 DYNA
comes with - SERT / 50 mm throttle body / 103 stroker kit - larger cylinders - pistons - etc. / httc heads ported heads & 10.5 pistons / roller rockers & supports / SE air cleaner / se 257 cam
Or for that kind of cash you might be able to go with a Zippers or Axtel or GMR Performance 124 type kit.TOMPAGLIA2 said:Anyone familiar with the SE 113 ci upgrade. Pro"s & cons for 06 DYNA
That's how I wound up with the 120". I went in to price out the 113" kit, but with all the added labor it was only a little more to go with the full motor, and then I still had my old 95" to sell, keep, whatever.wyodude said:Sounds good. How much?
I'll bet for the same $$$ you could go with a JIMS 120 in motor or an S&S 124 in motor.
TOMPAGLIA2 said:The price tag is around $6200. I am not familiar with a jims motor.
