Two charts are attached. One is the final results of my 107ci with TR-625 cams. The other chart is a comparison of the same engine with the TR-625 cams (tuned; upper curves) and the TW-8G+2 key (untuned; lower curves).
Below is the listing of components used on this build. Thoughts, comments or recommendations?
2002 Road King Classic
Mileage - 60K miles
SAE - 119tq/119hp
STD - 123tq/123hp
Uncorrected - 124tq/124hp
107ci All-Bore Engine (10.3 Static/9.4 Corrected - originally thought to be 10.5 static)
Tuned by JC Cycle Works
Dark Horse - Overhaul/weld/balance OEM crankcase/flywheel assembly
Axtell “4.125 x 4” Cylinders/Dome Piston (10cc) Kit
T-Man Stage III Heads (93cc/1.940" Int/1.615" Exh) and compression releases
S&S Roller Rockers
HD “B” Lifters and Camplate with Baisley/LMR oil pressure spring
Feuling Oil Pump
T-Man TR-625 cams
HPI 51mm Throttlebody w/4.9 gps injectors
Zippers MaxFlow Air Filter and Pushrods
D&D Fat Cat exhaust with Big Bore Quiet baffle
HD Premium Oil Cooler
TTS Master Tuner
3.37 final gear ratio
VP92T VPC w/SE clutch spring and easy-pull clutch ramp
In my engine, the TR-625 and TW-8G cams made the same level of valve train noise -- low.
The clutch plates will be replaced shortly. Took the bike on a 20 mile run in single digit temps, but it took that long to get the engine to somewhat warm up. A longer ride will be necessary to truly assess the bike's performance.
Mileage - 60K miles
SAE - 119tq/119hp
STD - 123tq/123hp
S&S Roller Rockers
Feuling Oil Pump
T-Man TR-625 cams
TTS Master Tuner
