I figure a bad guage or sender. All is like a big step higher that oughte to be. For no reason.
for a first check.
Then relief valve sticking.
Oil pressure pickup is after the relief valve which is right at the pump really. So at least you are getting lots of oil.
Course other things like any restriction at the filter, or oil cooler, etc could add to oil pressure if the relief valve is sticking close. Goes all through those things before going back into the engine.
Biesley spring
Mine runs at startup 58#. Then lowers as the engine warms to more normal levels, but always higher then stock. Idle arounf 15#. Cruising about 38-40.
Amsoil 20-50 in the Winter
Redline 20-60 in the Summer
Biesley's instructions, and or recommendations, is to polish the oil pressure relief plug with Emery clouth and make sure smooth operation.
I figure mine is set at 58 cause only goes that high when cold. Reguardless of which oil.
