Is it possible to buy the HD cast 103 pistons with cylinders only?
I have not been able to find a part number for the pistons and cylinders only. I do not want the AC, clutch spring, cams, gaskets, etc.
2008 Softail with a 96.
You should be able to go to a dealer and have them do a kit breakdown and tell you the part numbers.
Shift_Happens
You can buy the piston set and have your cylinders bored to fit or pick up a set on ebay to have bored.
I can try a different dealer for the parts breakdown. Just wanted to see the price of the cylinders with 20% off, compared to boring the stock ones. I don't know what Im getting when buying engine parts from ebay.
I have bought several sets on ebay...Just get some from a seller with great feedback
Shift_Happens
Same here....Then have them bored by a reputable shop.
SE flat top piston set-22942-00 standard bore
SE pro HC (10.5:1) for use with stock heads - 22144-08 standard bore
