Figured I'd post this as an FYI....
I have a 2011 FLHX 103 & wanted to reduce the heat from the motor due to the lean stock lean condition. I did not want to make the bike louder. I did a lot of research & spoke with a lot of smart people like Steve Cole & Jamie from Fuelmoto....
I ended up with 76hp & 92 ft lbs TQ.
& the bike runs a lot cooler... but remember... we are sitting on 103CI motors so it's not like air conditioning...
I bought the ceramic coated headers from Jamie. Very nice, high quality head pipes. I bought a SEST & SE Stage 1 AF from my local dealer. The dyno tech @ the dealer was little unsure of why I wasn't getting slip on as well ... he didn't think I the bike would make the power it did without slips....
When I picked it up lasr friday, he said he was very pleased with the power the bike makes & that it not only surpassed his expectations but that the bike made more power than similar mods with more open exhaust. He did however have to drill 1 small hole in each muff to get the exhaust sensor in the pipe. With the cats gone, the bike sounds good & runs great!
After I left the dealer, I was stuck in bumper to bumper traffic for 1/2 hour & the oil temp gauge (I had them remove the air temp gauge & replace with oil temp when I bought it) didn't move off the bottom. I thought the tech broke the sensor but I didn't want to turn back so I kept riding. After I finally got out of the 1st gear traffic, I blasted up an interstate & the the oil temp needle started moving ever so slowly. Before the tune, the oil temp would be at 230 & maybe slightly higher. The temp did go up to about 210 or so after blasting up the pike for 20 minutes & stopping at home but I think this will reduce the heat substantially.
I'll decide over the winter if I want to get slips.. other than that, I'm going to get chrome lower fork tubes & probably be done. The motor is strong & I am very satisfied with the power it makes.
