My 2003 fxst is coming up on 10000 miles service. I can change all the fluids, adjust primary and clutch. What else needs to be done. I've learned you cant trust the dealer to do it right. Want to be in good shape for trip to Mrytle Beach from Va riding all the way.
Ironbutt
Do you have a factory service manual? If not, get one - it'll be the best $50 you ever spent.
1000 mile Servie
You've covered the main areas. I believe they check some of the tq specks on motor mounts, lube clutch and throttle cables. I've always done all my own services myself. The service book is a good idea.
You will find that a 10000 will specify you check the torque on a number of "critical fastners." Also some odds and ends like air filter, steering head lube, and brakes. Some intervals call for things like steering head swing by and lube.
