2005 Fatboy with 98" big bore kit. Im Looking for a good mid to high range (2500-6000 rpm) cam for this setup. Heads are ported stage two with 1.90 intake / 1.610 exshaust. Must be a conversion cams. Thinking Andrews 54N? What are your thoughts?
My exp?
no two bikes run the same with the same cam.
I have become a Cam and seat whore.
If you are using the bike for touring I lean towards D.M stuff.
It might work further up the scale, but I have no exp in the real hot rod stuff.
Try something and see if you like it?
Make sure you have the room for it!
I had a set of Andrews 54's in my 07 103. It made 108 HP and 116 TQ. Peak torque was at 3,500 rpm. Peak HP was at 5,800 RPM. Also had Ported heads and HPI throttle body with Rinehart 2 into 1.
