07 ultra do I need to remap if I put a 2-1 on and stock A/C? "RESULTS"
PUT A V&H propipe on a 07 ultra 96 ci with the stock air cleaner. will the sensors dial it in? or do I need a download or tuning device?
Why stock ac? I say it should be remapped.
Here are the AFR's
this is what the afrs were with the stock ECM cal from the factory.
SAFE? :coffee:
DYNO SHEET
BLUE is the way it was delivered with the afr's i posted/
red is tuned with the stock air cleaner
pink is with the A/C removed...no extra tuning.
here is what the WOT (100%)AFR's were after tuned with the stock A/C
HER ARE THE wot (100%) AFR's with the stock A/C removed no extra tuning. notice they didnt change enough to warrant a retune.
and the diff between having the stock a/c on and taking it off. without the base run on the sheet.
