"What's this do?"
I want to install 07 SuperMegs on a 02 Road Glide so I will have O2 bungs. I spoke with Supertrapp customer service and they said there is a difference in the stock H-D mounting brackets. These stock brackets are re-used for the Supermegs installation. They are attached to the transmission. Anyone know if the stock bracket from a 07 will bolt onto an 02 without too much trouble? (I’m at work… don’t have the manual or the bike with me to look at.)
The new 07 will fit the older FLH, no problem. On the older SuperMeg, it used the stock bracket and a large hose clamp, you cna get that at any hardware store. The 07 SuperMeg uses a different (supplied) bracket and a P-Clamp to mount.
You can go to the SuperTrapp website and look up your specific bike/supermeg partnumber and down load the instruciton sheets to see the differences.
"What's this do?"
Right. The P-clamp, however, mounts to the 07 stock transmission bracket. I went to the dealership yesterday and looked at the bracket on a 07; it looks like it will fit a 2002.
Part numbers for the brackets:
65678-85D designed for pre-07
65678-07 designed for the 07​
You do not need a special clamp for a 02 bike, that is the point.
