What size is the nut that holds the clutch on in an 07( not at home right now). Im taking the 30 tooth off and going back to the comp 34tooth sprocket until there is some other option for us. I dont want to do the change on the trans sprocket so I will be waiting for a primary gearing change option. I just feel that direct drive is too hard on the drivetrain especially with the build im doing.
TIA
ZThat is the size for adjusted nut. I beleive the nut is 1 3/16". 1 1/2" for conpensator nut.
FYI 13/16 for comp and 1 3/16 for primary drive...on an 07
my 103 LIVES MMMMMUUUUUHHHHHHAAAAAAAAAA
HOLLY FREAKIN SNIKEYS!!!
Im doing MotoMan's break in so I have already felt the POWER!!!.. I went from 3.15 back to 2.79 and it is still unbelievable the power I'll post up the final build list later..im going for a RIDE!
You may be thinking of pre 07s and pre 06 dynas.
Those are 1 1/2 for comp nut and I think 1 1/4 for clutch, which has reverse threads.
