00 Fatboy said:
EFI has been around quite a while......why does it seem so more complicated on a bike than on cars??
I dont think it is..........but I wonder how I would have answered this 12 months ago............hmm.
GRock.............when he gets back on here is the forum guru for EFI...and his pearls of wisdom have enlightened many on here.
I have just purchased the SERT and have not applied it to my bike yet..........for a couple of reasons and none of them related to EFI.
The bike is purring on the DFO at the moment so I will wait until the rear wheel arrives before I get into the SERT.
The DFO is a worthwhile proposition in the beginning and is easy as to adjust...........its biggest draw back is fuel mileage........this will suffer because it can only add fuel and not subtract it.
I have been playing with the SERT for only a few days and can see that once I am used to its idyosyncracies I will be able to create maps at will.
I dont have a dyno here to throw the bike on and tune it in a few hours.........I do have an advantage in that I have raced bikes for quite a number of years and back in the 70`s when there was not much in the way of computer anything......especially for the privateers.............you made adjustments...........TOOK NOTES...........went out, checked times.....got a feel for how your adjustments affected performance, came in............WROTE DOWN YOUR RESULTS.............made additional adjustments........went out.....and so on and so on.
This applied to everything on the engine, then when you believed you got everything out of the engine you went after drive ratios to improve sector performance........then you went with tire pressures.............(to suit local weather and track conditions).................then you went after suspension mods.........changing front/rear bias for local track conditions ............stronger/weaker damper and rebound adjustments....then went back to tire pressures and then you were ready to race.
Each race then became two things most of the time............1st..........an experiment with all available adjustments..............2nd..............improving your own personal times through each sector.............occassionally you through it all to the wind and got to race someone.
All the best, Ozzie
