Well my experiement with the Roadhouse 2-1 (Flex Hose Design) was unsatisfactory.
It was more about personal tastes than anything. The pipe produced good numbers and had a decent sound. I did remove the baffle against the recommendation of the MFR. This did cause some slight discoloration of the canister. The Flex house was stainless steel and was bound to change colors even though I had a heavy exhaust wrap under it.
For more on this experiment everything is documented here: http://www.v-twinforum.com/forums/showthread.php?t=61488
I decided to move on to my favorite pipe of the month -- the D & D Fat Cat (pics will follow in a few days).
Link to D & D: http://www.danddexhaust.com/
Jeremy at Competition Cycles did the install and the Dyna Tune. If you are in the Houston area and not using these guys you should give them a try. He is meticulous when tuning. I do have a Power Commander and an Arlen Ness Big Sucker Stage Two.
He was able to squeeze out 78.62 HP and 81.83 Torque. This is a slight improvement (numbers-wise) over the Roadhouse which produced 75.58 HP and 80.97 Torque back in September.
Here is a link to the Dyno Report: http://www.geocities.com/achordc/05deluxe/05deluxefatcat.pdf
My thoughts on sound quality are that it is very tame at start up, but really has a nice low growl when you get on it. It is really quiet when out on the highway and cruising without accelerating. Like most pipes it sounds best when getting on it. However, my overall feeling is this is a great pipe if you live in a crowded area or want the ability to be kind to your neighbors. But you will not be disappointed when you get on it.
The quality is top notch with a very nice 2/3 heat shield.
Over this weekend I intend to take some pics and give more feedback.
My Roadhouse pipes will be up on Ebay soon through Competition Cycles. They do it for the exposure and I don't have to mess with the shipping.
Squid
Squid
