IIRC lowered springs are visibly obvious. If you check out pics of 03 FXD, a lowered bike has rear shocks that are several inches lower. Now, a 03 FXDL has more rake than an FXD and a lower seat as well. Those two things give a lowered seat position, feel, look and CG - but you can put the same FXDL seat on an FXD and have close to the same seat height. IIRC the FXD has 28 degrees rake and the FXDL is 32. So - if your bike has lowered springs - that's very obvious. WRT measuring seat height - I'd say compare it to your inseam as opposed to random measurements. Then go sit on a few bikes - if you can sit flat-footed, don't worry about it and if you can't - but are not unsteady, don't worry about it. Too easy to get wrapped up in overthinking pole-vaulting mouse turds. KISS.
