SportKing,
Yes, get the springs for your 'Glide from Progressive.
They will be variable wound. It doesn't matter if you install them tight coils up or down, they will work the same. Just make sure you put them in each fork leg either tight down or tight up. I always run them tight down to keep noise to a minimum and to make sure they doen't rub the dampning tubes.
Also, You'll need to cut your pvc spacer to the reccomended size for your bike. I always cut mine 1/4" longer so that the forks are a little stiffer, but that's just cause I like a firm suspension up front.
Make sure you use the supplied washer between the top of the springs and the spacers to keep the PVC from deforming over time.
Fork oil viscosity wil effect rebound more than it will compression. I like to run 30w on heavy bikes like the FL's to keep the "pogo-ing" effect to the minimum.
If you decide to keep the air suspension, run it at zero to start, the progressive springs don't need air to work. Also, If you do decide to remove the air suspension and the anti dive, make sure you keep al the grounds intact for the circuites that are stiled tied to the system. You may also have to remove a pin jumper in the wiring harness like I did for the front Brake light switch if you remove the soliniod. Good luck !
