Anyone know if the rear fender from a 2000 wideglide fit a 2002 wideglide?
I was told that the rear fender was widened in 02 from someone doing the opposite of what I am trying to do. I don't want to invest in tins I can't use.
If anyone knows please let me know asap as these tins will sell very quickly
:thanks:
Rear Fender for '02 Wide Glide
Cajunrider,
You are correct. The Dynas got a wider fender in '02. THe part number is 59918-02 meaning it changed in '02.
The widened it because the rear whent from a 130 to a 150
Same width
The fender is the same width. It's the way the fender bolts to the fender struts. H-d uses a shorter bolt and a tapped backing plate instead of washers and nuts. Just make sure the bolts don't rub on the tire.
I put a 150 tire on my 01 Heritage without a problem.
I have a 00 wide glide and already purchased an 02 rear fender by mistake. Is there any way to bolt it on without major modifications?
Greg
