Pulling the trigger on Progressive Monotubes : V-Twin Forum: Harley Davidson Forums
Old 01-20-2019, 10:24 AM   #1 (permalink)
wpc3's Avatar
wpc3 wants to know Dino or Syn?
Got the front end down to adjust steering neck bearings and replace broken fairing strut brackets with the USA made heavy duty ones. Decided to spend a few bucks and upgrade the front suspension. Did ÷hlins on the rear in 2018. Should be an improvement. Now that riding season has slowed down I’m pulling a big service. Get her ready for our road trip this year!
wpc3 is offline   Reply With Quote Quick reply to this message
Old 01-20-2019, 01:07 PM   #2 (permalink)
Malx's Avatar
Malx wants to know Dino or Syn?
Put some Ohlins on my SG this spring. I'd be interested in hearing how the front suspension works out for you..
Tis better to be silent and thought a fool, than to speak and erase all doubt.... Lincoln
Malx is offline   Reply With Quote Quick reply to this message
Old 01-21-2019, 12:59 PM   #3 (permalink)
wpc3's Avatar
I’m hoping for big gains. The neck bearings are very loose. I’ll get those corrected and the progressives in and update.
Old 01-22-2019, 12:52 PM   #4 (permalink)
flh120 wants to know Dino or Syn?
I installed a set of the Monotubes about 3 years ago. I've been happy with them. I can't say they were a big improvement over the progressive springs I had before but, no more leaky fork seals. You only add a couple of ounces of oil which is just a splash lube. I've heard some complain that they were too stiff but I haven't noticed it. I'm 66 and ride mostly back roads so if they were overly stiff I think I'd have noticed. I have noticed that my front tires wear more evenly than before. Not sure why. The old springs might have been the issue. In any case no more uneven wear.
flh120 is offline   Reply With Quote Quick reply to this message
Old 01-22-2019, 04:10 PM   #5 (permalink)
captainhook455's Avatar
captainhook455 is reading this now saying WTF is this?
How much did that run you?
Sent from my moto e5 supra using Tapatalk
captainhook455 is offline   Reply With Quote Quick reply to this message
Old 01-22-2019, 07:56 PM   #6 (permalink)
Malx's Avatar
If I remember correctly about $550.00
Old 01-22-2019, 08:39 PM   #7 (permalink)
Thank you kind sir.
Old 01-22-2019, 09:03 PM   #8 (permalink)
wpc3's Avatar
I figured I have it torn down for adjustment of neck bearings and replacement of broken fairing struts that I should install the progressive mono tube kit. My luck the seals would of puked after I put it all back together if I didn’t. Plus I wanted a better match to ÷hlins in the rear. I’m 66. All backroads. Which have not always been the best choice. Especially in California!
Old 01-23-2019, 08:13 AM   #9 (permalink)
Malx's Avatar
Originally Posted by wpc3 View Post
I figured I have it torn down for adjustment of neck bearings and replacement of broken fairing struts that I should install the progressive mono tube kit. My luck the seals would of puked after I put it all back together if I didnít. Plus I wanted a better match to ÷hlins in the rear. Iím 66. All backroads. Which have not always been the best choice. Especially in California!
You think you have some bad back roads.. Come to Maine!
Old 01-23-2019, 10:20 AM   #10 (permalink)
You have brought back some fond memories of one lane paved roads (bumpy) up and down little ridges that I couldn't see over the other side.
Old 01-25-2019, 01:39 AM   #11 (permalink)
roadking321 wants to know Dino or Syn?
MALX, I haven't ridden much of Maine but I know the year we went to Laconia, NH we rode most of the state except the southern portion, I thought the majority of roads sucked! Instead of the road cracks running across the road they all ran down the road - especially around Laconia. Thankfully we stayed in Woodstock, NH.
I installed monotubes in both my Road Kings & love the difference - handling/cornering & not bottoming out so easily when hitting bad bump unexpectedly. I highly recommend spending the $$ - both sets I installed are the lowered versions. I think I got 'em from Amazon just under $400.
2003 CVO FLHRSEI2 103" Rinehart TD; 57N cams; Progressive 944's & monotubes; Dynatek Fusion; 106tq 95hp
2000 FLHRCI 95" big valve heads, HPI MMXF TB; 26N cams; Progressive 440's & monotubes; Rineharts TD; TechnoResearch Directlink; 104tq 97hp
1988 FXR (not much stock)
1985 FXRS Low Glide Edelbrock Performer RPM heads, matching HC JE pistons; Crane 290-2 cam; Mikuni HSR42; ONLY thing stock is tranny! 88tq 84hp
Mustang seats & Metzeler 888's all around
roadking321 is offline   Reply With Quote Quick reply to this message
Old 01-25-2019, 07:37 AM   #12 (permalink)
Malx's Avatar
The last year or two the DOT has been re-paving quite a few roads around the state. They still have a long way to go. Surprisingly we don't have the amount of traffic since the population isn't that large. It's the weather that takes the toll.. It's always a surprise after the thaw.. Hence upgraded suspension definitely makes a difference..
Old 01-25-2019, 08:28 AM   #13 (permalink)
A frost heave man that is fun.
Old 01-29-2019, 04:58 PM   #14 (permalink)
wpc3's Avatar
Don’t remind me! I’m a cheap ol bastich. It doesn’t seem so bad a bit at a time. Yeah almost 4 bills for fronts and almost 600 for back. Stuff adds up! My glide rode like crap with oe rears. When I canned them the ÷hlins made the front feel like garbage.
Old 03-27-2019, 05:42 AM   #15 (permalink)
Malx's Avatar
So now I'm between two minds. Progressive FST @500.00 vrs the Legend Axeo. @ 750.00 then the Ohlins FKC 102 which cost even more. Anyone care to comment besides the price difference.. Will there be a notable difference other than a lighter wallet...
Similar Threads
Progressive 430's ordered, and a question about Monotubes JuiceMan Wheels, Tires, Brakes and Suspension 4 05-17-2013 05:36 PM
Installed Progressive Monotubes very easy! Bjax0175 Wheels, Tires, Brakes and Suspension 4 12-30-2011 02:56 PM
progressive monotubes ron baumer For Sale 0 08-21-2011 10:58 AM
Progressive front monotubes dennish Harley-Davidson Touring 1 08-22-2010 01:24 PM
Comparing front shocks: Progressive Monotubes to Ricor Intiminators Indenial Wheels, Tires, Brakes and Suspension 8 05-28-2010 11:23 AM
