FXSTDSE Resurrection troubles : V-Twin Forum: Harley Davidson Forums
Old 07-11-2019, 01:01 PM   #1 (permalink)
rdbug wants to know Dino or Syn?
HELP !!!!
I have become the care taker of my late brother-in-law's sweet ride that had been sitting for the last 14 years. I have cleaned the gas tank, replaced the fuel pump, regulator, injector's. Gone over every wire connection, and factory alarm system seem's to be working correctly.
Turns over and has spark & oil pressure but seem's to have no signal to the injector's so no gas coming out of them.
What am I missing ?
It is a FXSTDSE WITH A 1550cc 2003 limited edition.
rdbug is offline   Reply With Quote Quick reply to this message
Old 07-11-2019, 01:49 PM   #2 (permalink)
Armin's Avatar
Armin wants to know Dino or Syn?
Maybe the rest of the gas in the tank is unusable and has clogged the fuel filter inside the tank or even the injectors are clogged. Disconnect the fuel line from the fuel rail of the throttle body, direct it into a jar and switch on the ignition. If there is not a short shot of fuel coming, the culprit should be traced inside the gas tank (fuel pump, filter, regulator) and if there is fuel inspect the injectors including the electrical pulsing.
Armin.
Nothing can ruin a Man's Day faster than an almost Takeoff!
2001 FLSTCI
Heads ported and revalved to 95 CI BB by Technomotion, NL.
51mm HPI throttle body with Doherty Pacc AC
Wood TW9BG cams compression 10.8:1 @ 197 ccp.
Armin is offline   Reply With Quote Quick reply to this message
Old 07-12-2019, 09:48 AM   #3 (permalink)
I tested for spark by using spark plug test clamps that grounded out to the heads.
Have checked the fuel system by removing the fuel rail from the injector's. Fuel flowed very well, connected a momentary toggle switch to each injector while connected to the fuel rail and cranking the motor over. This gave me a very good fuel spray out of each one.
I have yet to see and voltage from the injector wire connections.
Old 07-15-2019, 01:53 PM   #4 (permalink)
eazyrydr wants to know Dino or Syn?
Hook up the components in question with different wires and if possible to a different battery not for too long just enough to see or read voltage and fuel pressure that will start your isolation journey to find the culprit possible fuel filter or fuel line blockage since it sat 14 yrs
eazyrydr is offline   Reply With Quote Quick reply to this message
Old 07-19-2019, 04:40 AM   #5 (permalink)
johnny_red wants to know Dino or Syn?
The ECU on my 2004 Fatboy failed while it was parked for a year. In my case it stopped the injectors at anything over about 60 percent throttle. Luckily my Tuner was able to confirm on the Dyno that it was in fact the ECU before I forked out for a new one and he was able to convince Dynojet to let me Marry my existing Powervision to the replacement.
johnny_red is offline   Reply With Quote Quick reply to this message
Similar Threads
Knuckle resurrection bbqbiker Choppers and Customs 14 02-10-2019 10:44 AM
1995 Electra resurrection Harv06 Harley-Davidson Touring 11 06-23-2014 06:39 PM
Happy Resurrection Sunday!!!!!!!!!!! dtroll Off Topic Discussion 6 04-08-2007 10:40 PM
Resurrection of the bike show in portland oregon mackshowtyme Choppers and Customs 0 10-06-2005 10:28 AM
Resurrection Of Rail System... supersport Off Topic Discussion 2 12-15-2004 10:04 PM
