Need Compression Reading in Pounds : V-Twin Forum: Harley Davidson Forums
Old 07-05-2019, 05:51 PM   #1 (permalink)
GHBiker wants to know Dino or Syn?
I have put in a fueling oil pump, S&S cams, S&S 89 cc Performance heads, and Keith Black 10.6/1 domed pistons. This is in a 2005 Dyna Twin Cam 88. My mechanic asked me to do 1000 mile break in b4 we remap the motor, so I put on about 1300 miles below 3500 rpm. During that time I used just a little better than 2.5 quarts of oil. My mechanic and I did compression test and what he called a leak down test. The leak down wasn't a true leak down, just waiting a while to see if the compression bled off. The compression readings were 160 on the front cylinder and 170 on the rear cylinder. My mechanic, whom I trust, felt these were great readings and, initially, so did I. I have since been presented with the information that, with the equipment we installed, we should have readings more in the 200 and above range.
Any thoughts or comments from some of you experienced builders out there? Where do you feel my compression readings should be and where did that much oil go????
GHBiker is offline   Reply With Quote Quick reply to this message
Old 07-05-2019, 06:02 PM   #2 (permalink)
CadtoChrome wants to know Dino or Syn?
where does your mechanic think it went??
CadtoChrome is offline   Reply With Quote Quick reply to this message
Old 07-05-2019, 06:12 PM   #3 (permalink)
autoworker's Avatar
autoworker wants to know Dino or Syn?
What cam (grind)?Without that information compression reading readings mean nothing here.
Too much oil usage for some reason.
Motorcycle Poor
autoworker is offline   Reply With Quote Quick reply to this message
Old 07-05-2019, 06:41 PM   #4 (permalink)
not sober all the time
Uncle Salty is still riding a stock bike Uncle Salty is still riding a stock bike
Use this calculator to get close. http://www.bigboyzheadporting.com/TwinCamComp.htm
Uncle Salty is offline   Reply With Quote Quick reply to this message
Old 07-05-2019, 07:42 PM   #5 (permalink)
Master Motorhead
Thermodyne's Avatar
Thermodyne joined the Live to Ride club Thermodyne joined the Live to Ride club Thermodyne joined the Live to Ride club Thermodyne joined the Live to Ride club Thermodyne joined the Live to Ride club
A motor that new should read almost identical front to rear.
And any wrench worth taking a scoot to would not have wasted time seeing how long the cylinder held pressure on a compression gauge. That's real shade tree stuff there.
Also, the correct map should have been in the ecm before you drove the scooter. You might hold off setting the final trims till after it had some miles on it, but unless it was mapped real close, like for a high compression 110, there could already be internal damage.
And as far as the oil use, if its not leaking it out, then its being burned. Camera down the plug holes should tell the tail on that.
Thermodyne is offline   Reply With Quote Quick reply to this message
Old 07-05-2019, 11:54 PM   #6 (permalink)
tall terry is still riding a stock bike tall terry is still riding a stock bike
it's like therm says,,, 2.5 quarts of oil in 1300 miles means tear it down again.. that is alot of oil,,
a proper map should have been loaded before the engine was fired up,,, much less ridden
I'm relatively sure there is internal damage,,, every motor I've built has near identical or identical compression readings... you dont want more than 180....
cam grind?
tall terry is online now   Reply With Quote Quick reply to this message
Old 07-06-2019, 04:59 AM   #7 (permalink)
The cams are S&S 510 C. Is that what you are asking by what grind?
Old 07-06-2019, 08:00 AM   #8 (permalink)
I see a rebuild in your very near future...
problems I see from the supplied info:
mismatch of compression and cams
170-160 ccp on a combo that should yield 200#,, also 200# is 20# too high for a good street build
2.5 quarts of oil useage
Old 07-06-2019, 09:45 AM   #9 (permalink)
Don Dorfman's Avatar
Don Dorfman is reading this now saying WTF is this?
You say your motor is 88". So you put the new pistons in these standard bores? Tell us more about the honing
Old 07-06-2019, 02:13 PM   #10 (permalink)
standard cross hatch honing. Thanks to all for responding
Old 07-06-2019, 02:31 PM   #11 (permalink)
Putting new pistons in a used bore without going oversized is usually a failure. The bores are not straight and true. To get them straight and true in a fixed hone will result is a loose fit and oil consumption is the result. Best fix is to go up to 95" especially with those heads. It will be a lot happier combination at 10.5:1
Old 07-06-2019, 04:04 PM   #12 (permalink)
Thanks Don. That is certainly food for thought.
Old 07-07-2019, 05:45 AM   #13 (permalink)
Thank you for all the responses. A lot of that info I do not have. The cams are S & S 510 C, the honing was standard cross hatch honing, The heads are S & S 89 CC performance heads, The plugs are light tan and seem to be burning properly, although the pipes are sooty. Todd, my mechanic, has built a number of performance engines. He admits he cannot explain the oil consumption, but has assured me that, if we go ahead with the remap and dyno, a costly affair, and something fails he will stand behind all of it, rebuild, reremap, and what ever else is necessary. I have ordered a leak down tester and a bore scope as he does not have either. we will employ them before we go forward with the remap.
Old 07-07-2019, 08:52 AM   #14 (permalink)
Oil goes by the rings, out the exhaust port and coats the pipes. If boring it costs the same to go to 95" as it does to 88" +.010 OS. Move up, the 95" is strong and proven. At the same time check the guides and valves seals. S&S is not perfect every time.
When a bore and hone is done properly these motors break in in a matter of a few miles. A good dyno shop will just run them at low speeds and upload some AFR fixes in the process turning off and on the motor and with fans this does the heat cycling. After they get some dyno miles on them and the low speed ranges are fixed they can make the full pulls and hand you a fully tuned motorcycle ready to go.
Old 07-07-2019, 10:20 AM   #15 (permalink)
Master Motorhead
Thermodyne's Avatar
What was the piston to cylinder wall clearance after you honed used jugs?
And please tell us you used a precision hone.
Similar Threads
Compression reading trustinHD Twin-Cam Engine 14 06-01-2012 10:14 AM
425 pounds of torque geoffreyt Harley-Davidson Sportster 8 12-23-2007 07:10 PM
Running high compression WITHOUT compression releases? Nightboy Twin-Cam Engine 29 11-26-2004 03:23 PM
50+ pounds of oil pressure at idle? itsafatboy Twin-Cam Engine 1 03-02-2004 12:52 AM
