2008 Ultra Neutral Problem / After Working on Main Gear : V-Twin Forum: Harley Davidson Forums
Old 06-06-2019, 09:56 PM   #1 (permalink)
rcass46220 wants to know Dino or Syn?
Replaced Main Gear Bearing and Sixth Gear seals/bearings. Didn't change anything on the transmission cassette. Reinstalled transmission, shifter pawl, shifted through gears, checked neutral - all seemed good. Reassembled primer, pipes, etc. Start bike in neutral and bike starts and acts like it is in gear, pull in clutch and bike starts in first and neutral. If I let out clutch bike is still in gear. Can't get bike in neutral. What did I miss or what can I test to resolve.
rcass46220 is offline   Reply With Quote Quick reply to this message
Old 06-07-2019, 10:53 AM   #2 (permalink)
Master Motorhead
Thermodyne's Avatar
Thermodyne joined the Live to Ride club Thermodyne joined the Live to Ride club Thermodyne joined the Live to Ride club Thermodyne joined the Live to Ride club Thermodyne joined the Live to Ride club
No idea. But if it will shift into neutral with the motor off, but not with the motor running, its a clutch issue 9 times out of 10.
Thermodyne is offline   Reply With Quote Quick reply to this message
Old 06-07-2019, 01:09 PM   #3 (permalink)
Armin's Avatar
Armin wants to know Dino or Syn?
Like Thermo suggested, if the gearbox has been assembled and installed correctly the proper clutch adjustment is of utmost importance. The change to another transmission and primary lube might help as well.
Armin.
Nothing can ruin a Man's Day faster than an almost Takeoff!
2001 FLSTCI
Heads ported and revalved to 95 CI BB by Technomotion, NL.
51mm HPI throttle body with Doherty Pacc AC
Wood TW9BG cams compression 10.8:1 @ 197 ccp.
Armin is offline   Reply With Quote Quick reply to this message
Old 06-09-2019, 10:12 PM   #4 (permalink)
Problem Solved
Removed transmission again, disassembled and reassembled, problem solved. Don't know what was not correct. All fixed.
Old 06-10-2019, 04:46 AM   #5 (permalink)
Armin's Avatar
Very good!!!
2001 FLSTCI
Old 06-10-2019, 05:37 PM   #6 (permalink)
duuude's Avatar
duuude wants to know Dino or Syn?
I had the same thing happen in a 73 Z28 I had in the mid 70's when I was a kid... Seemed like something didn't line up right when I tightened up the case bolts ( a 4 speed I had put new bearings and a reverse gear in) and I put a bind on it...
Like you, worked great the second time....
duuude is offline   Reply With Quote Quick reply to this message
Similar Threads
2008 Ultra Classic - speaker not working fikmik2000 Harley-Davidson Touring 3 04-26-2015 02:19 PM
Main shaft main drive gear and sleave jameslowz28 Transmission and Primary 0 07-15-2013 09:58 PM
5th gear whine ... 2008 Ultra ... starts after 15k mikes? Ultra RB Harley-Davidson Touring 11 06-12-2012 04:52 AM
Neutral light stays on after 6sd Gear install mainmusic Twin-Cam Engine 1 12-27-2005 10:18 PM
Main Shaft Drive Gear Removel srlancealot Twin-Cam Engine 7 07-28-2004 07:39 AM
