Shovelhead plus 0.080" overbore : V-Twin Forum: Harley Davidson Forums
Go Back   V-Twin Forum : Harley-Davidson Motorcycle Forums > Technical Discussion Forums > Pre-Evolution Engines
Old 03-25-2019, 03:59 AM   #1 (permalink)
Lukas's Avatar
Lukas wants to know Dino or Syn?
Hi guys,
Gonna bore early shovel jugs for 080 over. Is that safe? As the cylinder wall at the spigot will be 0.080". Believe that this is the last repair size...
Road King 2003
98" CP pistons, domed +3ccm
CR 10.1:1
cylinders bored and honed by myself
heads-ported and milled by myself - 84ccm chambers
S&S 570 cams
S&S SUPER E carb
Dynatec 2000 ign.
HIvol oil pump
Heritage Softail 2003
95 flat top pistons
static compression ratio 9.82:1
Andrews tw37b cams
S&S super E carb
Crane ignition Fireball H4
87 Hp, 107 FTLB of torque
1943 WLA bobber
____________________________________________
RIDE NOW, WORK LATER!
Lukas is offline   Reply With Quote Quick reply to this message
Old 03-25-2019, 08:07 AM   #2 (permalink)
Ddaddyo's Avatar
Ddaddyo wants to know Dino or Syn?
Wiseco makes Pistons for the +.0800 Shovel.
https://www.zippersperformance.com/w...4-pistons.html
Ddaddyo is offline   Reply With Quote Quick reply to this message
Old 03-25-2019, 11:51 AM   #3 (permalink)
Master Motorhead
Thermodyne's Avatar
Thermodyne joined the Live to Ride club Thermodyne joined the Live to Ride club Thermodyne joined the Live to Ride club Thermodyne joined the Live to Ride club Thermodyne joined the Live to Ride club
80 over was pretty common back in the day.
People used to talk about them cracking, but I never saw one do it.
Just to be clear, those 80 over builds were not stepped on. They were 7.0:1 stock builds. Usually people trying to use jugs someone else discarded when .060 wore out.
Thermodyne is offline   Reply With Quote Quick reply to this message
Old 03-25-2019, 02:15 PM   #4 (permalink)
Lukas's Avatar
Interesting that Wiseco does not make 070 size....
Road King 2003
CR 10.1:1
S&S 570 cams
S&S SUPER E carb
Dynatec 2000 ign.
HIvol oil pump
95 flat top pistons
Andrews tw37b cams
S&S super E carb
1943 WLA bobber
Old 03-25-2019, 05:26 PM   #5 (permalink)
Master Motorhead
Thermodyne's Avatar
Drag still lists them in their Old Book.
Old 03-28-2019, 04:26 PM   #6 (permalink)
pb68slab's Avatar
pb68slab wants to know Dino or Syn?
NO! , Material gets real thin and porous at the root of the cooling fins. I've seen they break at .050 over!
Later 1980 and later 80 Cu.In jugs are already .060 over a 74 , and will take .020 more.
S&S makes jugs of a much stronger cast ductile iron. They ain't cheap , but they won't break!
Stay away from the aftermarket Taiwanese jugs.
"Clowns to the left of me,
Jokers to the right!"
pb68slab is offline   Reply With Quote Quick reply to this message
Similar Threads
How much overbore on 4.060 cyls? n.e.confederate Twin-Cam Engine 36 01-27-2012 03:46 PM
SE 113" cylinder overbore? DaleW Twin-Cam Engine 5 02-01-2011 04:04 AM
040 Overbore On 1340 Evolution Cylinder clifton63 Twin-Cam Engine 4 12-06-2007 01:49 PM
PM Phaqtail Plus, Plus, Plus ndwgolf Choppers and Customs 5 03-17-2004 11:51 PM
