2005 Ultra Classic Stereo won’t power on unless speaker switch is off : V-Twin Forum: Harley Davidson Forums
Old 06-11-2019, 08:39 AM   #1 (permalink)
CookUltraClassi's Avatar
CookUltraClassi wants to know Dino or Syn?
I have an odd issue with my factory stereo that I can’t figure out.
First, the stereo will not power on when the ignition switch is turned to ignition like it should, or when the bike is running.
Once the bike is started, or switch in position, the stereo won’t power on. Not just in standby, but completely off. You have to flip the speaker rocker switch to the topmost position. All speakers off, and bam! Stereo powers on. Once its on, you can flip the rocker switch and turn the speakers on.
The second issue is the display is scrambled. You can JUST BARELY make out the volume level but it’s nearly impossible to read the display. Other than that, everything functions as it should. It works perfectly, other than the scrambled display, and not powering on unless the speaker switch is off.
I have the upgraded fairing speakers, and one of the soldered leads were pulled off of the small PCB when disconnecting the speaker leads. I resoldered it, and the speaker works fine, but that is the only issue I can think of that might have something to do with the speaker rocker switch affecting the unit powering on. Like I said, it functions perfectly otherwise.
Any idea on what could cause this? The scrambled display and power issue may be two separate issues. I plan to bend the pins of the display and check their connection between the head unit and display panel, but I’m stumped on the powering on issue.
Any help is much appriciated.
CookUltraClassi is offline   Reply With Quote Quick reply to this message
Old 06-11-2019, 02:59 PM   #2 (permalink)
Greg_E wants to know Dino or Syn?
I'd guess bad power supply where it can't get enough current to power up when it is also trying to push to the speakers. Speakers off would be less power draw and might be a small enough inrush to allow things to power up. I'd get it serviced from a third party, there is one place that specializes in repairing Harley radios but I don't remember the name.
My miniGP racing stuff: http://minigp-racing.com
Greg_E is offline   Reply With Quote Quick reply to this message
Old 06-11-2019, 10:55 PM   #3 (permalink)
Make me use my bullet?
<G Man>'s Avatar
<G Man> joined the Live to Ride club <G Man> joined the Live to Ride club <G Man> joined the Live to Ride club <G Man> joined the Live to Ride club <G Man> joined the Live to Ride club
Iron Cross Audio Repair
http://www.ironcrossaudio.com/
G Man
Meddle not in the affairs of dragons for you are crunchy and taste good with ketchup.
Silence is golden , duct tape is silver.
Stay back 200 feet - not responsible for damaged feelings.
The biggest problem with social media is that it has caused so many people to falsely believe that someone gives a sht about their stupid-assed opinions.
<G Man> is offline   Reply With Quote Quick reply to this message
Old 06-12-2019, 09:59 AM   #4 (permalink)
smitty901's Avatar
smitty901 is still riding a stock bike smitty901 is still riding a stock bike
Iron cross to fix the radio if that is the problem. Go back remove all the work you did put it back as it was then try it. Most often that fixes things quickly.
Infantry leads the way
smitty901 is offline   Reply With Quote Quick reply to this message
Old 06-12-2019, 12:13 PM   #5 (permalink)
tall terry is still riding a stock bike tall terry is still riding a stock bike
listen to smitty always flow. backwards from the most recent to oldest work when chasing electronics....
both sircuits feed off the auxiliary harness,,, from the ignition switch. it could be a high resistance,,, bad connection, etc all you need is volt ohms amp meter and a test light... there are some really functional tools available for diagnostics literally plug and play
tall terry is offline   Reply With Quote Quick reply to this message
Similar Threads
Rear Brake light won’t light up 716shovelhead Electrical, Wiring and Lighting 10 06-18-2019 09:49 PM
Won't start unless in Neutral ABQ-Jammer Harley-Davidson Dyna 4 06-17-2019 03:32 PM
2005 Ultra Stereo won’t power on unless speaker switch off CookUltraClassi Electrical, Wiring and Lighting 1 06-11-2019 08:48 AM
96 Sportster fuse is clicking; bike won’t start gnar_nasty Harley-Davidson Sportster 3 11-01-2018 04:30 AM
won't idle unless choked. can anyone help? 96XLH883_820 Harley-Davidson Sportster 8 03-25-2010 09:49 PM
