Rear Brake Light Switch Issues : V-Twin Forum: Harley Davidson Forums
Old 04-08-2019, 11:01 AM   #1 (permalink)
slowlane wants to know Dino or Syn?
Hey Guys- Been a long winter with lots of nasty mag-chloride on the roads, but given me a chance to wrench on the 2000 Softail Heritage. Custom painted tins installed, rebuilt wire wheels, new exhaust installed, cam tensioner inspection, all fluid change, rebuilt both brake calipers. The rear caliper was dragging on one side and when I popped out the pistons, I found aluminum milling debris inside one of the passages! Presumably from manufacture. Blead the system, now the brake switch works only with a very hard press on the peddle. Front works like a charm. Could I have a bubble of air in the switch causing it to work only when pushed very hard? I know these switches are troublesome, but it was working fine before.
slowlane is offline   Reply With Quote Quick reply to this message
Old 04-08-2019, 01:02 PM   #2 (permalink)
tall terry is still riding a stock bike tall terry is still riding a stock bike
if you left the caliper in place while bleeding,, I would suggest that you still have air in the rear system...
step back and have a look at where the bleeder is,,, and where the MC is,,, the MC port is lower than the bleeder,, and the bleeder is not the highest point on the caliper,,, so.... you need to address all this and re bleed it..
try this,,, remove the caliper,,, leave the pads in,,, put a lock between the pads,,, then lower the caliper to the ground,, or lower than the mc,, then open the bleeder,,, pull and hold the lever,,, and close the bleeder,,, continue until all air is removed... be sure to hold the bleeder to the highest point...
then reinstall,, and pump the lever,,, slowly until the pads contact the rotor and lever travel is at a minimum,, 5hen check the light,,, check the front switch as well,,,, the front is an electric switch ther rear is a pressure operated hydraulic,, with 2 wires at the top of the switch..
tall terry is offline   Reply With Quote Quick reply to this message
Old 04-08-2019, 10:12 PM   #3 (permalink)
Good point. After a lot of bleeding, l finally did get the peddle pretty hard. Iíll give this a try and re-bleed lower than the MC and hopefully this will fix the issue.
Old 04-10-2019, 10:12 AM   #4 (permalink)
let us know how it works out,, ok?
Old 04-14-2019, 10:39 PM   #5 (permalink)
Will do. I may not get to it for a week or so. More snow here and lím getting tired of it, so headed to AZ.
Old 05-07-2019, 05:06 PM   #6 (permalink)
Finally got to this and tried re-bleeding as recommended, but it turns out it was the switch, which is rather inexpensive- only about $22. Same part number used for years, but with many updates- up to "E" I believe. The newer switches are easier to get a wrench on. The old one was a bit of a challenge- ended up using a 25mm 12 point socket, while not perfect worked Ok.
Old 05-07-2019, 06:28 PM   #7 (permalink)
probably got a bit of the shrapnel in the switch restricting movement,,,, or,, those switches fail all the time,,,, it was first used in 1957 iirc the last 2 digits of the part # are 57 then the alpha prefix...
they are a pain to remove,,, I have a socket made just for them..
Old 05-07-2019, 08:20 PM   #8 (permalink)
pb68slab's Avatar
pb68slab wants to know Dino or Syn?
Only 2 types I can think of used on a Harley are flag/spade terminal and ring/screw terminal.
Ya can get both types at NAPA for about $12.
ID:	245350   Click image for larger version
"Clowns to the left of me,
Jokers to the right!"
pb68slab is offline   Reply With Quote Quick reply to this message
Old 05-08-2019, 01:56 AM   #9 (permalink)
Kickman's Avatar
Kickman wants to know Dino or Syn?
Ive seen a few bikes that had bad wheel bearings and the hub was shifting side to side on the axle, with it, the brake rotor screwed to it, pushing the pistons in caliper in, making the brake soft next time you step on the brake lever, all it takes is .005-.008" movement which is why a a warped rotor will feel the same. Brakes pump up until the rotor spins through the caliper pressing the pistons back into the caliper making the lever and pedal soft again
Kickman is offline   Reply With Quote Quick reply to this message
Similar Threads
Brake light switch pushrod switch plate johnboy77 Harley-Davidson FXR 5 05-25-2018 05:41 AM
Front brake activates the brake light but the rear brake doesn't MadCity Electrical, Wiring and Lighting 7 06-06-2012 04:22 PM
Rear brake light switch issue. jetdoc Harley-Davidson Softail 1 11-16-2005 11:07 AM
Rear brake light switch question 748*2Risk Harley-Davidson Softail 4 05-15-2004 11:55 PM
Rear Brake light switch removal? strange246 Twin-Cam Engine 3 04-11-2003 07:46 AM
