Rear brake light switch question : V-Twin Forum: Harley Davidson Forums
Old 05-15-2004, 06:43 PM   #1 (permalink)
748*2Risk wants to know Dino or Syn?
How do I go about attaching a brake light switch to my foot brake? I would like to buy the switch and it's bracket (but will fabricate it if I have to) but don't know what kind to get, I have attached a picture of my controls - I'm not sure who makes them.
748*2Risk is offline   Reply With Quote Quick reply to this message
Old 05-15-2004, 09:05 PM   #2 (permalink)
DrHeathenScum wants to know Dino or Syn?
could you use a pressure activated switch in-line, like the stock setup?
"43" Pantless Assclown
DrHeathenScum is offline   Reply With Quote Quick reply to this message
Old 05-15-2004, 09:23 PM   #3 (permalink)
Damm I am stupid, I have a in-line switch at the "t" intersection that I never saw. How do I test the switch to see if that's my problem?
Old 05-15-2004, 09:35 PM   #4 (permalink)
Ed Y's Avatar
Would be nice if you said what your problem was. Does the brake light stay on all the time or does it never come on?
One wire going to the switch is hot with the ignition on, the other becomes hot when switch is activated and feeds the rear brake light. If the light is staying on all the time, disconnect one of the wires on the switch. If that fixes it, the switch is bad. If it doesn't, then the problem is somewhere else. If the light doesn't come on, then use a test light to see if you got voltage at the switch. If you do, pull both wires off the switch, touch them together, the brake light should come on. If it does, the switch is bad.
Ed Y
Retired Navy, MCPO
Old 05-15-2004, 11:55 PM   #5 (permalink)
Thanks Ed, I should have made it more clear. The brake light is not working so I will give your tips a shot.
