upper rear shock mount 54309-87 : V-Twin Forum: Harley Davidson Forums
Old 04-10-2019, 07:35 AM   #1 (permalink)
havinabubble's Avatar
havinabubble wants to know Dino or Syn?
Question upper rear shock mount 54309-87
anyone know which year this is off?
...and how did it actually mount to a bike?
One end appears to have a nut machined onto a smooth stud,
and the other end has a 30mm deep thread (which I presume a bolt goes into from the INSIDE edge of the fender? through the rail
curious to know how you where supposed to get a shock off, if you had to remove the inside fender bolt (or was there a threaded stud on the frame rail?)
havinabubble is offline   Reply With Quote Quick reply to this message
Old 04-10-2019, 08:12 AM   #2 (permalink)
Racepres's Avatar
Racepres is reading this now saying WTF is this?
^^ I'm gonna venture, those are the Shock mount [stud] used after the Strut [shock angle] change..
as I recall... you need to at least hold the Inner Fastener..
Racepres is offline   Reply With Quote Quick reply to this message
Old 04-10-2019, 08:24 AM   #3 (permalink)
tall terry is still riding a stock bike tall terry is still riding a stock bike
since the last 2 digits are 87,,, it was first used in 1987...
tall terry is offline   Reply With Quote Quick reply to this message
Old 04-10-2019, 08:44 AM   #4 (permalink)
brad75raiders's Avatar
brad75raiders wants to know Dino or Syn?
May not be stock but I have them on my91
Sent from my SM-N960U using Tapatalk
brad75raiders is offline   Reply With Quote Quick reply to this message
Old 04-10-2019, 08:49 AM   #5 (permalink)
ahhhh do you now! thanks
and do they bolt like I said from the INSIDE?
so if you wanted to remove the shock you'd have to get up over the wheel to release the mounting bolt? (I guess you'd turn the machined nut while holding the fender bolt still)
trying to figure out if I can adapt this to replace my temp fix that I have on a busted stud
Old 04-10-2019, 08:50 AM   #6 (permalink)
Racepres: why do folk change the angle? to lower/higher?
and
cheers TT
Old 04-10-2019, 08:53 AM   #7 (permalink)
Thet push into the shock from the outside and have a bolt on the inner fender fasten them together. But I reversed the bolt so the sleeve is pushed through the inside to mount my sportie bags
Old 04-10-2019, 09:02 AM   #8 (permalink)
ahhhh interesting!
NICE BIKE btw, and great pics of where this bolt should go. BIG HELP
Old 04-10-2019, 09:21 AM   #9 (permalink)
Racepres's Avatar
and
cheers TT
The MoCo moved the top of the shock forward for appearance I guess...The Original FXR had the shocks more Vertical than the Later [I forget what year] Ones. Personally I feel the Handling was compromised in doing that... You can spot the Early ones easily by the Early style fender Strut.
Old 06-11-2019, 10:41 PM   #10 (permalink)
nairbg's Avatar
nairbg wants to know Dino or Syn?
Can you relocate the shock to the original mounting point, on the later frames, and use the earlier strut covers?
nairbg is offline   Reply With Quote Quick reply to this message
Old 06-12-2019, 05:43 AM   #11 (permalink)
Alan S's Avatar
Alan S just installed tassels Alan S just installed tassels Alan S just installed tassels
I hope so. I've got an early fender in my shop. Just waiting on Racepres to get me my early struts.
Sent from here to there.
You can avoid reality, but you cannot avoid the consequences of avoiding reality.
Ayn Rand paraphrase
Rules read.
Alan S is offline   Reply With Quote Quick reply to this message
Old 06-12-2019, 07:39 AM   #12 (permalink)
Mikefox wants to know Dino or Syn?
If I remember right,on my 84 there is a light on the frame there. Should not need a new fender . There is a gap between the fender and the lug. May have to pull the fender to install it.
But you would definitely need the newer style strut.
I think people move them for eye appeal. I think the newer ones flow with the frame better.
But the angle change would help with sporty/fxr slanted bags fitting better.
I got a set here that would fit good if I had more angle on the shock.
Mikefox is offline   Reply With Quote Quick reply to this message
Similar Threads
Rear upper shock mount spacers / washers? havinabubble Harley-Davidson FXR 6 04-01-2019 03:11 AM
Upper shock mount rcrideout My Story, the Beginning... 1 09-04-2018 01:17 PM
How to remove upper shock mount on '86? havinabubble Harley-Davidson FXR 8 05-09-2016 02:26 AM
upper shock mount studs, diff years? FXRS84 Harley-Davidson FXR 8 12-22-2011 11:51 PM
Shock stud upper mount nut rickr01 Harley-Davidson Dyna 3 02-03-2005 10:05 AM
