Sputter Low RPM : V-Twin Forum: Harley Davidson Forums
Old 04-04-2019, 07:41 PM   #1 (permalink)
Jake707SBFMC wants to know Dino or Syn?
Sputter Low RPM
Bike has a nasty sputter below 2k rpm. Pretty much wont let me take off hard from a stop I have to easily roll on throttle and ride the clutch out. Here’s a couple vids I sent to the tuner. His initial take is it sounds more electrical than fuel related.
Thoughts what I should be looking at?
Here’s one of a couple take offs from a stop.
https://youtu.be/hclioMmpNtw
Here’s one at idle stabbing the throttle in neutral.
https://youtu.be/6H_zR8qZnW8
Love CA. Hate the jerk offs runnig it.
Jake707SBFMC is offline   Reply With Quote Quick reply to this message
Old 04-04-2019, 08:32 PM   #2 (permalink)
ecir45's Avatar
ecir45 is reading this now saying WTF is this? ecir45 is reading this now saying WTF is this?
You going to hurt that motor doing that. I would increase the idle speed jet until it disappears.
ecir45 is offline   Reply With Quote Quick reply to this message
Old 04-04-2019, 08:44 PM   #3 (permalink)
Misters's Avatar
Misters wants to know Dino or Syn?
Yeh, don't do that. Each time you whack the throttle raw gas is shot into the intake... to be followed up with no air. That action also screws with the VOES.
https://youtu.be/gQ1D_1A9ds4
Misters is offline   Reply With Quote Quick reply to this message
Old 04-04-2019, 10:08 PM   #4 (permalink)
Not running VOES. Ultima says not to with their motors
So you think it’s a jetting issue then?
Old 04-05-2019, 03:31 AM   #5 (permalink)
tall terry is still riding a stock bike tall terry is still riding a stock bike
yes it can hurt it in a very expensive way... I run a 35 low jet in my 113,, and my G has had the full zippers treatment... it just pulls, or pulls harder... and has no stutters, sputters or flat spots... from idle through 6500,,, any gear, any speed,,,,
tall terry is offline   Reply With Quote Quick reply to this message
Old 04-05-2019, 06:26 AM   #6 (permalink)
Ok. Will I need to adjust air mixture screenor just replace jet?
Old 04-05-2019, 06:33 AM   #7 (permalink)
ecir45's Avatar
another thing to check is your ignition curve. May be a symptom of full advance coming in to fast.
Old 04-05-2019, 10:01 AM   #8 (permalink)
you will probably have to take the air fuel screw in about 1/2 turn,,, it varies from engine to engine..
Old 04-06-2019, 01:00 PM   #9 (permalink)
Thanks guys. I’m wonder why the tuner thought it was an electrical issue before jetting. He’s solid and still interested in helping me just getting the bike to his shop an hour away is a timing issue lately.
Old 04-11-2019, 06:55 PM   #10 (permalink)
Ok talked to the tuner again and removed the air cleaner and gave it full twists. Here are two videos of it with the accelerator pump screw all the way in like it was.
You can see some of the twists didn’t shoot much of any fuel.
https://youtu.be/kBGPn8SCg1s
https://youtu.be/wipQMDGpgvM
Old 04-11-2019, 06:58 PM   #11 (permalink)
And here’s a vid inside after 3.5 full turns out on the accelerator pump screw. Not much change. Let me know what you guys think next. Thanks.
https://youtu.be/hlUG-pXyFP0
Old 04-11-2019, 08:31 PM   #12 (permalink)
you have a problem with the accelerator pump,,,clogged passage torn diaphram or blocked passage would be my first choices to look for...
Old 04-11-2019, 08:44 PM   #13 (permalink)
Ok. Sounds like I need to look up a video on how to take the pump out haha
Old 04-12-2019, 03:46 AM   #14 (permalink)
3 screws on the bottom of the housing,,, take the bowl off to make it easy,,,, 2 check balls and 2 o rings,,, all are small
Old 04-12-2019, 10:17 AM   #15 (permalink)
I think I can handle that lol
What should I be looking for?
Similar Threads
RPM and low rpm torque build Qs 78738 Twin-Cam Engine 37 08-31-2010 05:05 AM
Very Small Popping at 1800 rpm to 1400 rpm Thorns EFI Maps and Calibrations 1 07-15-2009 11:34 PM
[email protected] RPM Help? Cozza Twin-Cam Engine 6 12-30-2006 06:22 PM
Gear + RPM's = MPH, solve for RPM's petrock Harley-Davidson Softail 1 01-23-2006 08:38 AM
Cough..Cough...Sputter. Sputter Captain Bligh Twin-Cam Engine 11 09-13-2005 05:13 PM
