Recommendations for transmission and primary oil - Page 2 : V-Twin Forum: Harley Davidson Forums
Old 05-21-2013, 07:38 AM   #16 (permalink)
georgedouglas's Avatar
Originally Posted by RF_R_US View Post
So my riding buddy and excellent auto mechanic gave me serious grief about my choice for transmission oil. I put in Mobil 1 synthetic 90W140 gear oil. I've been around motorcycles all my life so this wasn't done on a whim and I noticed an immediate improvement (although it wasn't bad before) in the shifting (less "clunk"). He says 20W50 is what the HD stuff is that's called out in the service manual and that the detergent keeps the solids in suspension vs. sinking out. Me, I think I'd rather have gear shavings sink to the bottom vs. being in suspension but anyway that's his "view" on this. I think most folks have mentioned that any real oil would work in the transmission as long as it's changed regularly and the primary one fellow told me could probably run on "pee" and still work and I agree as it's just a chain which is usually exposed on chain drive bikes. Thanks for the thoughts....
John
The detergants in motor oil are not capable of holding metal shavings in suspension like it can combustables so this theory is all wrong. Also once break in has occurred you should not keep making shavings or something is wrong with the tranny. Use whatever product you feel comfortable with.
george
Old 05-21-2013, 08:05 AM   #17 (permalink)
Anvildyno wants to know Dino or Syn?
Originally Posted by jakenok View Post
Transmission is a a gear box: put gear oil in it.
Primary case, just about any oil will work. I use B&M Trik Shift ATF.
Yep, agreed.
Transmission I use a 85-140 fully synth Gear oil. Smooth as silk gear changes and protects the gears very well.
Other holes I use a 20W-60 fully synth.
Primary oil is only there to lube the chain drive, cool the clutch and wash any wear particles to the bottom of the case to get them out of the way until the next change
Been using this combo for years trouble free.
Not sure what brands you have available local over in the US but I use Penrite in Australia
Anvildyno is offline   Reply With Quote Quick reply to this message
Old 05-21-2013, 08:10 AM   #18 (permalink)
jammer45u's Avatar
jammer45u is reading this now saying WTF is this? jammer45u is reading this now saying WTF is this?
John
Not a correct assumption on the primary.
Our bikes, unless modified to a belt primary drive, use wet clutches. Similar to the automatic transmission in most cars, they are designed to slip and need proper lubrication.
I'm quite certain piss, even highly exotic, synthetic goat piss, wouldn't adequately protect the components in your primary case.
jammer45u is offline   Reply With Quote Quick reply to this message
Old 06-17-2013, 07:08 PM   #19 (permalink)
Turk05 wants to know Dino or Syn?
My service guy at the dealer mentioned that while they are fine with good quality synthetic oil in the engine, and they put Redline in their transmissions, (except Bakers that call for ATF I believe) but he was adamant that the primary should have the Harley fluid in there. He said they had seen enough primary issues with many other fluids, so they stick with the HD and have good results. Just something to consider...
Turk05 is offline   Reply With Quote Quick reply to this message
Old 06-18-2013, 09:51 AM   #20 (permalink)
pssthecarp wants to know Dino or Syn?
+1 on Redline Shockproof. I use it in 05 RK. Quieter butter smooth shifts.
pssthecarp is offline   Reply With Quote Quick reply to this message
Old 06-18-2013, 11:52 AM   #21 (permalink)
duuude's Avatar
duuude wants to know Dino or Syn?
I tried the redline 80 - 140 ( the green stuff) and I didn't like it at all. shifts were harder ( 06 Fatboy) and it just clunked more. that was at 10K miles after using harley gear oil.. I just switched the Syn 3 and it seems to be the best its been for shifting smoothness.
Is the Shockproof the 240 wt ( pink stuff) Thanks
duuude is offline   Reply With Quote Quick reply to this message
Old 06-18-2013, 12:27 PM   #22 (permalink)
self banned
Road King Cole's Avatar
Road King Cole is still riding a stock bike Road King Cole is still riding a stock bike Road King Cole is still riding a stock bike
I just recently switched from Spectro's synthetic heavy duty tranny oil to Royal Purple heavy duty tranny oil as well as Spectro's primary oil to a Dex ATF fluid.
All I can say is WOW!!!
What a difference!
I mean, WOW, I can't tell any difference. Bike still shifts and changes gears just fine.
The main reason I switched was to have different color fluids as I have a random seepage issue I want to track down.
rkc
2016 Ride of the Year Winner!
Road King Cole is offline   Reply With Quote Quick reply to this message
Old 06-18-2013, 05:30 PM   #23 (permalink)
Olivepearl wants to know Dino or Syn?
Redline heavy Shockproof tranny and HD formula + primary
Olivepearl is offline   Reply With Quote Quick reply to this message
Old 06-18-2013, 06:53 PM   #24 (permalink)
qtrracer's Avatar
qtrracer wants to know Dino or Syn?
Any primary fluid like Rev Tec, Drag Specialties, HD Formula +, Bel-Ray(it's red like atf) that you can get the easiest is fine. Any trans fluid meeting the specs for these transmissions is fine. None of them will facilitate easier or quieter shifting despite what you read.
"You have to inspire yourself. I am my own role model. I want to be me." Vincent Lepak 2008
qtrracer is offline   Reply With Quote Quick reply to this message
Old 06-18-2013, 07:10 PM   #25 (permalink)
hdrider1's Avatar
hdrider1 wants to know Dino or Syn?
I agree 100% -- the person who thinks it doesn't make a difference has obviously not tried Redline Heavy Shockproof.
hdrider1 is offline   Reply With Quote Quick reply to this message
Old 06-18-2013, 07:40 PM   #26 (permalink)
qtrracer's Avatar
I have it in my bike now, ZERO difference between that and HD Formula+ . It isn't going back in at the price they want for it.
Old 06-18-2013, 08:45 PM   #27 (permalink)
hdrider1's Avatar
Shockproof goes in the transmission, not the primary.
Old 06-18-2013, 09:17 PM   #28 (permalink)
qtrracer's Avatar
Shockproof goes in the transmission, not the primary. If you put HD Formula+ in the tranny it probably wouldn't even shift. What planet were you from again?
If you would actually look into fluid recommendations rather than just pour in whatever some counter jockey sold you would find out that HD Formula+ is recommended for the transmission and primary and is factory fill in most if not all big twin primaries and transmissions.
Old 06-19-2013, 12:32 AM   #29 (permalink)
05fatboy95's Avatar
05fatboy95 wants to know Dino or Syn?
I use all amsoil. 20w50 in engine. Severe gear in tranny and super shift in primary. No issues or complaints.
Using the same oil in all 3 holes just doesn't make sense to me. Would u put heavy gear oil in your engine? Your tranny is a bunch of gears so use gear oil. Your primary is a wet clutch so use something designed for that purpose not an all-in one type thing. Just my 2cents..
Sent from Motorcycle.com Free App
2005 fatboy
BVBOB built 107"
built with all used parts.
05fatboy95 is offline   Reply With Quote Quick reply to this message
Old 06-19-2013, 07:56 AM   #30 (permalink)
self banned
Actually no, I haven't tried it. Being that it is 75W250 as apposed to the others I tried which are ~75W90/75W140, perhaps there may be a slightly noticeable difference.
If one was going from 20w50 to 75W250, sure I would bet there may be a noticeable difference. Putting engine oil in the tranny (or primary) makes no sense to me either.
I guess the more specific point I should of emphasized was that changing oil brands\types with the similar viscosity in the primary\tranny; there shouldn't be any noticeable difference in noise\shifting etc...
Will I try redline shockproof? Maybe, maybe not, tranny works and shifts fine.
rkc
