Speed sensor pulse rate??? : V-Twin Forum: Harley Davidson Forums
Old 05-19-2007, 01:35 PM   #1 (permalink)
Mac4020 wants to know Dino or Syn?
Anyone know what the pulse/mile rate is for HD VSS? I'm adapting an electronic cruise control for my '05 FXST and need this info to set it up properly.
Thanks-
Mac4020 is offline   Reply With Quote Quick reply to this message
Old 05-19-2007, 01:50 PM   #2 (permalink)
springer-'s Avatar
I don't know what it is but you could calculate it to get started and then adjust it for real world later if it is not close enough.
A guess on how to calculate it (having never done so before)
1 Lift rear tire off ground
2 Remove speed sensor from transmission
3 Rotate rear tire until tire valve stem is on bottom to use for reference point
4 Rotate tire one full revolution and count the number of teeth that pass where the speed sensor would have been
5 Measure the circumference of the tire
5280 feet/mile divided by the circumference measurement = tire revolutions/mile
Then tire revolutions/mile multiplied by the number of teeth per tire revolution should equal the approximate number of pulse per mile from the speed sensor.
Sounds complicated but really should only take a few minutes to accomplish.
This is just a guess but it is where I would start if I could not find the information needed.
Check out Ride of the Month
Old 05-19-2007, 03:02 PM   #3 (permalink)
AirGlider's Avatar
AirGlider wants to know Dino or Syn?
Daytona Twin Tec rates the FXSTD VSS at 1382 Hz at 100kpm (60 mph). You can refer to: http://www.daytona-twintec.com/downl...structions.pdf
Page 13 has the table.
AG
'04 Blue Ultra
DTT TCFI IID
95" Bored Cylinders & Cast Flat Top Pistons
Supertrapp Supermeg 2/1- 18 discs
Woods TW 6G
Big Boyz Heads (10:1cr) 77cc chambers
H-D Reduced Effort Clutch
Garmin 2720
Baisley Spring
Loud Lights SAVE Lives!
AirGlider is offline   Reply With Quote Quick reply to this message
Old 05-19-2007, 06:48 PM   #4 (permalink)
Thanks Airglider- Assuming the frequency in the table is cycles/second, I figure it's running 84000 pulses/mile. Unfortunately my cruise only has settings up to 38000, so it looks like I'll be using a magnetic pickup instead of the VSS.
