Leslie Kay'sBikeBandit
SportbikeTrackGearMotorcycle.com Classifieds!Dan Vance RacingMotorcycle.com
Old 07-24-2006, 11:08 PM   #1 (permalink)
ChazInNJ is on a distinguished road
Dual to Single...
Thinking about a new tire/rim combo. I am thinking about going from dual brakes up front to single. Anyone know what i would need to accompolish this ?
2004 Lava Red Sunglo Road King Classic
1974 XLH
ChazInNJ is offline   Reply With Quote
Old 07-25-2006, 02:43 AM   #2 (permalink)
84FXRP is on a distinguished road
Dual to single would require a different master cylinder (single disk set-up), different brake line (single caliper), and a different fork slider (w/o the caliper attachment lugs). Your new wheel would be set-up for a single disk - to reuse the old wheel you would need to remove the brake disk and purchase the appropriate spacers/wheel trim rings for a single brake disk system.
84FXRP is offline   Reply With Quote
Old 07-25-2006, 07:43 AM   #3 (permalink)
I kinda knew what needed to be done, I know about the lines and master cylinder. What slider would i use (ie from what bike)?
1974 XLH
Old 07-25-2006, 11:08 AM   #4 (permalink)
Your profile shows you have a 2004 FLHRCI, why not just get a machine shop to turn down the current slider? (Actually I would get (use) a spare slider and keep the original in case you decide to sell the bike - I suspect most folks would want the standard dual disk set-up.)
Old 07-25-2006, 07:39 PM   #5 (permalink)
I aldready have chrome lower forks. I don't want to turn down a perfectly good lower leg, and then rechrome it again... Isn't there anything I can buy ? Would the fork from the heritage softail work ? It looks the same size as a road king, and does not have the tabs for the caliper..
1974 XLH
Old 07-29-2006, 09:38 AM   #6 (permalink)
Still_on_2whls is on a distinguished road
Heritage front ends look similar to the Touring, and despite the FL usage in their names.....are different. Specfically the outside diameters at the base are different, fender mounts are different, fenders are different, wheels are different. Air pressure is interchangable.
Still_on_2whls is offline   Reply With Quote
Old 07-29-2006, 09:40 AM   #7 (permalink)
The Alter Ego
Rock's Avatar
Rock is on a distinguished road
So you want to lose some braking power?
Sweep around your own front door, before you try to sweep around mine.
Rock is offline   Reply With Quote
Old 07-29-2006, 02:12 PM   #8 (permalink)
DILLIGAF
berserker's Avatar
So you are giving up safety for looks? I want more stopping power. Lots of people go for aftermarket brakes. Some people seem to think HD lacks in breaks, and you want less.
Wow.
Old 07-30-2006, 11:53 AM   #9 (permalink)
I didn't think i asked for opinions about this setup. I wanted to know if anyone has done with with parts that you can buy. Go jump on somone else's thread who wants to change things that you do not like.. Leave mine alone...
1974 XLH
Old 07-30-2006, 01:32 PM   #10 (permalink)
DILLIGAF
berserker's Avatar
Free country do what you like. Same token, I can say I wouldn't give up safety for something pretty. Good luck to you.
