MU85B16 vs. MT90B16 Dunlop 402 2003 FLHTCUI : V-Twin Forum: Harley Davidson Forums
Old 01-10-2005, 12:08 AM   #1 (permalink)
Beserker wants to know Dino or Syn?
I have a 2003 FLHTCUI Ultra Classic in need of a rear tire. The front is okay, so I need to stick with a Dunlop in the rear.
Will the tires from the 2004/2005 Ultra Classics fit on the 2003? I would prefer the deeper tread and higher load characteristics of the newer tire.
Has anyone put the MU85B16 on a 2003 Ultra and had any problems? Apparently Dunlop has a different size in mind.
http://www.dunlopmotorcycle.com/fitmentguide.asp
Harley-Davidson | Model: FLHTCUI (99-03) - Ultra Classic Electra Glide
Tire : D402 | Size : MT90B16
Make: Harley-Davidson | Model: FLHTCUI (04) - Ultra Classic Electra Glide
Tire : D402 | Size : MU85B16
Beserker is offline   Reply With Quote Quick reply to this message
Old 01-10-2005, 01:31 PM   #2 (permalink)
Highly Seasoned Rider!
newultraclassic's Avatar
newultraclassic wants to know Dino or Syn?
Might work.
Speaking of the rear tire:
They mentioned somewhere in the literature when I bought my '04 Ultra that the '04 FLHTCUI's were fitted with a 160mm rear tire. (I mean 150mm....oops.) I assume that the MU85B16 that you mention is a 150. I looked in my '04 Touring parts book and the latest fender number that they show has a dash 02A number on it. The swing arm and axle show a dash 02 part number. Assuming that they didn't change the rear fender or swing arm and axle in '03 a 160 should fit.
My guess is that it would work based on part numbers. Like everything else, though, you will never know until you try.
The front should work, IMHO. The fender looks the same all the way back to 1949.
newultraclassic is offline   Reply With Quote Quick reply to this message
Old 01-10-2005, 10:17 PM   #3 (permalink)
Clayton wants to know Dino or Syn?
Nope, the MU85B16 is the stock tire beginning on the 2003 Heritage Springers and on most of the 2004's and up. It's a 150.
Clayton is offline   Reply With Quote Quick reply to this message
Old 01-11-2005, 10:28 AM   #4 (permalink)
That's right, I meant to say 150. FIrst year on the FLH's was 2004. Should fit on a 2003 based on part numbers.
Old 01-11-2005, 10:36 AM   #5 (permalink)
Ed Y's Avatar
I think the size of the rear belt was changed when HD went with that new size tire. I also seem to remember that Markcuda said somewhere that he put a MU85 on his 03 EG. The different in the width is .31. Probably can be done if the rubber piece on the belt guard at the bottom is trimmed.
Ed Y
Retired Navy, MCPO
Old 01-11-2005, 11:11 AM   #6 (permalink)
RIght you are about the belt. It has a 2004 part number. (40024-04). So they may well have changed to a narrower belt in '04 to match the 150 tire in the rear.
Old 01-11-2005, 02:51 PM   #7 (permalink)
Ed Y's Avatar
Did you notice it's getting to be nightmare trying to keep up with all the changes from year to year? Ain't no more of the old days when a part from a 10-15 years ago would fit right on a new one. I guess it's good in a way as it's progress the majority of the time.
Ed Y
Retired Navy, MCPO
Old 01-11-2005, 03:55 PM   #8 (permalink)
Infidel
wyodude wants to know Dino or Syn?
Not to mention the revenus stream from everyone trying to get 2 extra centimeters
wyodude is offline   Reply With Quote Quick reply to this message
Old 02-04-2005, 06:55 AM   #9 (permalink)
pwdby460 wants to know Dino or Syn?
Hi,
The sprocket, and belt are the only differences I know of. Someone asked in a later issue of American Iron about this, they said the frame was changed, but I have found no evidence of this. I've called Harley but have found no-one that can or will tell me all the differneces to accomodate the larger rear tire.
Have a nice day,
Dan
Dan's Rumble House
pwdby460 is offline   Reply With Quote Quick reply to this message
Old 02-08-2005, 06:42 PM   #10 (permalink)
MPZ
MPZ wants to know Dino or Syn?
MU is a 140, not a 150. And it should fit with the belt guard trim Ed mentioned. And note the 85 aspect ratio which will make it about the same height as the front tire.
MPZ is offline   Reply With Quote Quick reply to this message
Old 02-12-2005, 02:34 AM   #11 (permalink)
we blew it man
twinontwin's Avatar
twinontwin wants to know Dino or Syn?
Beserker, just put the mu85 on my 03 E G, needed to trim the belt guard flap to clear, it would spin freely but was right on the tire.The belt is REAL close to the tire, have not rode it yet finishing other work.Gonna keep a close eye on it if it rubs at all I will yank it quick. let you know what happens.
twinontwin is offline   Reply With Quote Quick reply to this message
Old 02-14-2005, 07:27 PM   #12 (permalink)
we blew it man
twinontwin's Avatar
its a no go on the mu85, just too close to belt, no room for tire flex.fits the 03 EG fine otherwise. the extra load cap and tread depth would have been nice but not worth springing for the narrow belt and pulleys.
Old 02-14-2005, 10:36 PM   #13 (permalink)
Yup, I sit corrected. If you go to the Dunlop site, the tire is a 5.5 inch width or 139.7 mm or 140 tire. My mistake. I guess after this set wears out, I'll try and fit a true 150 on.
Old 02-15-2005, 01:58 PM   #14 (permalink)
honnky wants to know Dino or Syn?
Just a little tidbit...I put the MU on my 96 FXSTC. At first glance everything was fine. Very close to the belt but still about an 8th inch clearance. After riding for about 50 miles I noticed that the top run of the belt was touching. I have decided to live on the edge and ride it.
honnky is offline   Reply With Quote Quick reply to this message
Old 03-28-2005, 11:27 PM   #15 (permalink)
Wrench
powerhaulic's Avatar
powerhaulic wants to know Dino or Syn?
I also just got a MU rear for my '03 RK, we'll see how it goes.
'06 FLHT 98"
'88 XLH
'78 FX
'75 XLH
powerhaulic is offline   Reply With Quote Quick reply to this message
