If you do the rear only than you may not need one. Especially if you stay closer to 1.5" instead of 2" Alot of the times you run into problems is when you lower the front and rear. But just to be safe you can pick one up at Ness for arount $60 or so. It's 1" shorter and really helps the lean angle. That way if you do ever lower the front you'll be set.
I use one on mine but I'm at 4" under on the front end with Legends kit in the back. I'm really at the limit of this stand so I may have to get an adjustable one to be safe (btw also available through NESS). Good Luck!
Originally Posted by Boondog
Couldn't find a straight answer after my search . . . I plan on lowering my FLSTF 1.5 - 2" (rear only) & wondering if I'll need a shorter stand. Thanks.
