It should not be a problem. Just consider yourself lucky that the tire didn't blow off the rim and try and bite you. The problem with overinflating tires, is that as you ride, the tires heat up. As the tires heat up, the air inside the tires heats up. Heated air is denser, which will raise the pressure even more. If your tire should have 36lb in it, and you put 40lb in it, once the air heats up, it probably will have 45lb in it. That is too much pressure for the tire, and the tire can fail. But just adding too much pressure, which you corrected before you rode, shouldn't have damaged the tire.
Don
