Elite 3 vs 402s : V-Twin Forum: Harley Davidson Forums
Old 12-07-2012, 06:53 AM   #1 (permalink)
Steelernation is on a distinguished road
Elite 3 vs 402s
Heard good things about the Elite 3's but have always used the 402's or Avons. Need tires looking for some input any thoughts?
Steelernation is offline   Reply With Quote
Old 12-07-2012, 09:15 AM   #2 (permalink)
BD 110's Avatar
BD 110 is on a distinguished road
I went from the D402's to the E3's on my 02 SE Road King. The E3's perform much better in the twisties, run quiet, and have given good service life so far (8500 miles) I will be using these in the future on this bike. FWIW.
JW
Axtell cylinders w/ JE 4.135 flat top pistons
T-Man Street Elite heads
T-Man 590 cams
54mm HD-HPI TB w/ Pro High Flow Injectors & Heavy Breather
TTS BUB 7 TD
Dark Horse Pro Plug crank AIM VP92T
BD 110 is offline   Reply With Quote
Old 12-07-2012, 09:21 AM   #3 (permalink)
jammer45u's Avatar
jammer45u is on a distinguished road
You should like the E3's much better than the 402's. Corner like the Avons, stable straight and level like the 402's.
You might want to consider the Commander II's as well.
jammer45u is offline   Reply With Quote
Old 12-07-2012, 12:19 PM   #4 (permalink)
RogerDodger is on a distinguished road
So far I like my first set of E-3's. They don't follow cracks, tar snakes and rain grooves like my old 402's did. Everything else seems about the same, handling-wise.
RogerDodger is offline   Reply With Quote
Old 12-07-2012, 12:56 PM   #5 (permalink)
Ironman1120's Avatar
Ironman1120 is on a distinguished road
ditto on what the others have said. On my second set. Gives you confidence in the turns and doesn't track. Night and day vs stock.
Ironman1120 is offline   Reply With Quote
Old 12-07-2012, 09:04 PM   #6 (permalink)
tenn.vol. is on a distinguished road
Yes to ALL they said, I have just over 10K miles on a set and the rear
I have to look close to see any tread wear. Now my son he twistes his
much more than I do and I can see wear on his with 10K miles.
I will for sure replace with the same E3..And I replace early as you
cant make any money trying to get the last 100 miles out of the tire,
and you go down........tenn.vol.
tenn.vol. is offline   Reply With Quote
Old 12-08-2012, 01:53 PM   #7 (permalink)
gb1500 is on a distinguished road
e-3's last long but are noisey and cupp...402's too hard and last long but go downhill as they age...i got a bad one by the way and no more...i want to try commanders2...i had reg commanders on and they are the perfect tire
gb1500 is offline   Reply With Quote
Old 12-10-2012, 01:35 PM   #8 (permalink)
95BadBoy's Avatar
95BadBoy is on a distinguished road
I have the E-3's and love them. way better than the 402's
1995 Bad Boy, Engine built to Stage 4 in 1998
Branch #5 heads, Matching Branch 11.8 Pistons
SE big bore intake manf W/42mm Mikuni
SE-57 cam, Crane 3/8 molly adj push rods
32" x 2.25 OD exh pipes Hyper charger air cleaner
Dyna 2000i adj ignition sys.
Blue streak Hi Opt coil W/10mm wires.
Dynoed at 93.5 HP
95BadBoy is offline   Reply With Quote
