Who's Springer Front End : V-Twin Forum: Harley Davidson Forums
Old 12-03-2012, 11:41 AM   #1 (permalink)
JOKERS IMPALA's Avatar
JOKERS IMPALA
I was looking through ebay for springers and came across this one, the listing doesnt say who the manufacture is and asking the seller didnt help either. I liked the fact that the rear fork actually slides through the bottom tree and up into the top tree and is secured with pinch bolts, different from what Ive seen before.
2009 Night Train
Roland Sands A/C
Black Big Shot Staggereds
PCV & Autotune
Andrews 54H Cams
S&S 106" Big Bore
SE Clutch Spring
Battastinis Grips
JOKERS IMPALA is offline   Reply With Quote
Old 12-04-2012, 01:55 AM   #2 (permalink)
JOKERS IMPALA
The listing ended, I havent been able to find any other info or pictures of this front end. It kind of mimics the design of american suspensions. Any help is greatly appreciated
2009 Night Train
Roland Sands A/C
PCV & Autotune
Andrews 54H Cams
S&S 106" Big Bore
SE Clutch Spring
Battastinis Grips
Old 12-04-2012, 02:00 AM   #3 (permalink)
JOKERS IMPALA
From the listing
Fat Custom Springer Chrome Front End
Stock Harley Length
Bigger, better old school fat springer front end.
New and improved for 21013
Featuring heavy duty construction, triple trees with spiked nuts, better than DNA, CCI, or anyone else!
Fully Chromed Custom Springer Front End.
Triple plated chrome.
Accepts 1984-99 Left or Right Side Brakes, and Wheels with 3/4" - Diameter Axles.
9" wide at the axle.
The reinforced top and bottom trees reduce flex and improve handling.
TIG welded alloy steel construction for strength and durability.
Fits most Harley Big Twins from 1949 to present with 1" neck bearings.
Kit includes: main spring, fork leg, neck, top nut, crown nut, rocker assemblies with brass bushings and top top clamp for Glyde style risers plus axle with axle nuts, washers and spacers.
Stock length.
2009 Night Train
Roland Sands A/C
PCV & Autotune
Andrews 54H Cams
S&S 106" Big Bore
SE Clutch Spring
Battastinis Grips
Old 12-04-2012, 01:53 PM   #4 (permalink)
JOKERS IMPALA
So the seller finally responded to me and said the front end is a DNA, I know DNA has had issues in the past with their front ends and figuring thats why they went to this setup. Only time will tell to see how this front end holds up to real world use
2009 Night Train
Roland Sands A/C
PCV & Autotune
Andrews 54H Cams
S&S 106" Big Bore
SE Clutch Spring
Battastinis Grips
Old 12-09-2012, 09:58 PM   #5 (permalink)
Arse Hole and Good at it
FL8X's Avatar
FL8X is on a distinguished road
Sorry man for the late post on this. Yeah diffidently looks like a DNA frontend. Here the post I did a few years back of the DNA Springer,
http://www.v-twinforum.com/forums/ha...t-train-2.html . It worked out for me and really did like the ride, only thing that threw me off on it was the squared off look of the frontend and it just didn't seem to flow with the Night Train lines. I ran it for a while and had no issues with it.
2010 SG
PCV
V&H Power Duals
V&H Monster Ovals
SE Stage I Cleaner with K&N Filter
Andrews 48H Cams
Polk Audio MM651
Rockford Fosgate PBR300X2
FL8X is offline   Reply With Quote
Old 12-09-2012, 11:19 PM   #6 (permalink)
JOKERS IMPALA
Well this design is a different than the traditional dna, Its not for my night train, but looking for a replaement for the old mans springer that he was in a wreck on
2009 Night Train
Roland Sands A/C
PCV & Autotune
Andrews 54H Cams
S&S 106" Big Bore
SE Clutch Spring
Battastinis Grips
Old 12-17-2012, 09:41 AM   #7 (permalink)
harley2006 is on a distinguished road
The picture's look identical to the ones on Demon's Cycle website. If so, I think it is a DNA.
I've seen E-Bay sellers selling there stuff before. It can be bought pretty cheap.
harley2006 is offline   Reply With Quote
