Riding with a bad fork seal? : V-Twin Forum: Harley Davidson Forums
Old 11-04-2012, 07:38 AM   #1 (permalink)
thebreez's Avatar
thebreez is on a distinguished road
Promise my wife we would ride this morning eat and go to the anniversary party at Palm Beach Harley, just notice one of the fork tubes has oil on it when I pump it.
It shows over 30 people on here now, is it safe to take a slow short ride?
1994 FXRP SE Heads, 42 Mikuni, EV46Cam,
Dyna SF Ignition, Bub 2into1, 10to1 Compression.
Lockhart oilcooler
Love the Torque
thebreez is offline   Reply With Quote
Old 11-04-2012, 07:42 AM   #2 (permalink)
RG50 is on a distinguished road
As long as the front does not feel different,I say it should be OK.
2011 Electra Glide Limited
RG50 is offline   Reply With Quote
Old 11-04-2012, 08:45 AM   #3 (permalink)
skitz43's Avatar
skitz43 is on a distinguished road
I agree,just try not to use front brake to often. Depending how much fluid you loose your steering may wander at speed a little.
2011 FXDF
Cat removed
Xoid
Cycle shack slip ons
K&N sucker
Smoke tail lite & signals
Custom made sissy bar
Avon Grips
Saddle bags
Custom cut windshield
skitz43 is offline   Reply With Quote
Old 11-04-2012, 08:52 AM   #4 (permalink)
Rollmeaway's Avatar
Rollmeaway is on a distinguished road
My first question would be how much oil are we talking, & secondly how far are you from the action/party.
Front fork seals usually leak because of a worn slider bushing which allows excess lateral movement of the tube in the leg.
We never even said a word,
And we rolled...
Dare...
2000 FXST - Carbed
Rollmeaway is offline   Reply With Quote
Old 11-04-2012, 11:24 AM   #5 (permalink)
Thermodyne's Avatar
Thermodyne is on a distinguished road
As long as it's leaking, and you are aware of it, you can ride it. That doesn't mean that you can take it on a long trip, or enter it in a rodeo. The trade off is that you could cause some additional damage, depending on what caused the seal to leak.
"All mankind is divided into three classes: those that are immovable, those that are movable, and those that move."
Thermodyne is offline   Reply With Quote
Old 11-04-2012, 03:28 PM   #6 (permalink)
Fourcats's Avatar
Fourcats is on a distinguished road
We rode back from Lewiston, ID {350 miles} with a bad fork seal on the LowRider. You loose some dampening and its messy.
Fourcats is online now   Reply With Quote
Old 11-04-2012, 06:16 PM   #7 (permalink)
cycleman is on a distinguished road
Many times a fork seal leaks because of a piece of grit caught between the seal and the fork leg. Try a product called seal mate ( query it ) and see if that cures your problem. If it doesn't you'll have to replace the fork seals in both sides.
The fork oil should be changed in both legs once you got the leak stopped.
And yes it can be ridden a short distance, but I wouldn't put any 500 mile days on it unless I was caught in no man's land with the bike, then you do whatever you have to.
cycleman is offline   Reply With Quote
Old 11-04-2012, 06:44 PM   #8 (permalink)
Rollmeaway's Avatar
Seals & Bushings are 15.00 per side out the door & thats from the Stealer. Being a '94 maybe its time to end the story.
And we rolled...
Dare...
2000 FXST - Carbed
Old 11-04-2012, 07:51 PM   #9 (permalink)
tmd11111 is on a distinguished road
You can ride it till it stops leaking, the damage is already done. At worst you loose the dampening effect the oil has other then that and a some oil splattered no other damage is going to happen. When you do repair it inspect your fork tube for any knicks or damage that could cause a tear in the seal and check the slider bushing for wear. These are the two main reasons for fork seals leaking. Third reason is usually from coming down too hard when doing wheelies, generally we can rule that out with most harleys.
tmd11111 is offline   Reply With Quote
Old 11-04-2012, 08:37 PM   #10 (permalink)
93Horse's Avatar
93Horse is on a distinguished road
Which tube, right or left? If left be sure that it's not neck bearing grease.
"Our lives begin to end the day we become silent about things that matter"
93Horse is offline   Reply With Quote
Old 11-04-2012, 08:39 PM   #11 (permalink)
gusotto is on a distinguished road
Getting the Progressive Cartridge System installed now.
Bushings were starting to leak, even though I didn't know it.
Getting the bushings replaced, along with the fork tubes that were showing some abrasion.
When they get the job done, I want all the parts good because it would be expensive and time consuming to pull it apart again.
With the Cartridge system, no fork oil needed.
gusotto is offline   Reply With Quote
Old 11-04-2012, 09:00 PM   #12 (permalink)
93Horse's Avatar
I asked the question because of thew location. WPB FLA is warm and with a bike on the jiffy stand for extended times, may show signs of oil on the left fork from the neck bearing grease.
Old 11-04-2012, 11:54 PM   #13 (permalink)
Thundermug's Avatar
Thundermug is on a distinguished road
Originally Posted by Fourcats View Post
.... You loose some dampening and its messy.
Yeah, this....I had one go on me when I went to the mountains this past July. It was messy and the oil got all over my bike and on my brakes. I could still stop but it took me longer to stop.
After getting the bike fixed I went to a car was and used a high pressure wand in addtion to the brush. I was still getting oil off the bike 2 weeks later at home. It was messy.
The Doctor said I have ADD but I don't think I...Hey, look a chicken!
Thundermug is offline   Reply With Quote
Old 11-05-2012, 03:34 AM   #14 (permalink)
Half_crazy's Avatar
Half_crazy is on a distinguished road
What makes you think that?
Victory Kingpin
110" Stroker/Big Bore,
Half_crazy is offline   Reply With Quote
Old 11-05-2012, 08:43 AM   #15 (permalink)
Rendell's Avatar
Rendell is on a distinguished road
It seems to me that you are going to the right place. I'd see about getting the forks worked while I was there.
06 FLHTCUI Ultra Classic
Rendell is offline   Reply With Quote
