Originally Posted by Slayer63
Damn. I go two weeks without internet and one pops up on ebay. What did you get her for if you don't mind me asking?
I believe any style that works with the oem swingarm should work.
Sorry for the delay in responding.
I picked it up from Ebay in UK for 325GBP.
Regarding the bearing/cleveblock issue, there seems to be some issues.
An email received in October 2012 from the new manufacturer of the JMC 'arm, Abbey Engineering, advised that OEM cleveblocks will fit without the tolerance ring.
The CCE swingarm upgrade may not fit. In an email CCE advised measuring the JMC 'arm bore (1.726 inch approx) to compare with the OEM 'arm (1.748/1.750) Given the differences it will be "difficult or impossible" to fit CCE bearings.
Abbey Engineering also advised that, due to "a few problems", the production of the JMC is currently on hold. Things nay have moved on since then.
