Buzzing front ... bearings? : V-Twin Forum: Harley Davidson Forums
Old 08-13-2012, 09:06 AM   #1 (permalink)
universitybiker wants to know Dino or Syn?
Unhappy Buzzing front ... bearings?
2007 FLSTF 2003 Anniversary
Don't think I have a bearing problem but on Saturday I noticed a load of "Buzzing" from the front end when cornering, OK in straight line and varies depending on the road type.
Tyre is in good condition only done 9000 miles any ideas
universitybiker is offline   Reply With Quote Quick reply to this message
Old 08-13-2012, 10:34 PM   #2 (permalink)
gb1500 wants to know Dino or Syn?
id check em ...easy enough to pull the wheel off...cheap enough to replace....or a brake pad problem
gb1500 is offline   Reply With Quote Quick reply to this message
Old 08-13-2012, 10:50 PM   #3 (permalink)
Merc63 wants to know Dino or Syn?
My front bearings just went and they were making loud clunking noises, no buzzing.
Merc63 is offline   Reply With Quote Quick reply to this message
Old 08-14-2012, 01:06 AM   #4 (permalink)
HATER OF THE GRAVEL!!!!!!
Jeffytune's Avatar
Jeffytune is reading this now saying WTF is this?
Drop the tire down, put your thumbs on each race pushing down and roll the tire on the floor and feel for any roughness. There should be some resistances, stiffness to movement.
If it is glass smooth, put it in neutral and roll the rear tire, if it feel like a box or rocks, welcome to my world, you have a main shaft bearing failure in the transmission.
I'm Just Sayin'...
2010 FLHTCUI
96 CID w/ the quiet 6 speed
K&N RK-3930 air filter
Harley quiet high flow 110 mufflers
Vance and Hines Fuelpak
Professional Rockat Surgen
Disclaimer.
Jeffytune is offline   Reply With Quote Quick reply to this message
Old 08-14-2012, 03:40 AM   #5 (permalink)
OK Guys thanks for the tips and advice.
I'll get it up on the stand at the week end and take a look
Old 08-14-2012, 05:28 AM   #6 (permalink)
autoworker's Avatar
autoworker wants to know Dino or Syn?
Make sure your tire pressure isn't low.I would also inspect the brakes.
Motorcycle Poor
autoworker is online now   Reply With Quote Quick reply to this message
Old 08-14-2012, 07:16 AM   #7 (permalink)
Master Motorhead
Thermodyne's Avatar
Thermodyne just installed tassels Thermodyne just installed tassels Thermodyne just installed tassels
I had the same thing on my 2011 FLTRX. I could feel the buzz in the bars on exit ramps. Pulled it down and found NOTHING at all with the bearings. Called my scooter rabbi and he said to lower the air in the tire a little. Problem solved.
Thermodyne is offline   Reply With Quote Quick reply to this message
Old 08-14-2012, 08:25 PM   #8 (permalink)
i like 36+/- in front a little spongier than a hard 42...rear stays at 41
Old 09-17-2012, 02:33 PM   #9 (permalink)
OK finally got to replace the bearings and although they did not seem bad the difference is amazing. The buzzing has gone.
Thanks for all advice on this one
