Sealing spoke rims for tubeless tires : V-Twin Forum: Harley Davidson Forums
Old 07-07-2011, 11:02 AM   #1 (permalink)
Voldog wants to know Dino or Syn?
On a previous bike with spoke rims, I sealed the spokes with 3m5200 quick drying marine sealer so I could run tubeless tires. It worked well but messy applying the sealer. I was wondering if there was something else that could be used to seal the spokes.
Also, are there places that seal and true spoke rims? I think my 99 Fltcu rims could use a little truing.
Voldog is offline   Reply With Quote Quick reply to this message
Old 07-07-2011, 03:20 PM   #2 (permalink)
NJ Rider's Avatar
NJ Rider wants to know Dino or Syn?
Voldog;
I wouldn't use 5200 on the spokes. That stuff is just below welding, adherence wise. If you get the wheels trued, they won't be able to turn the nipples.
I'm figuring you have stock wheels. Use the rubber strip that covers the spoke nipples.
Any good indy should be able to true the wheels.
NJ Rider is online now   Reply With Quote Quick reply to this message
Old 07-08-2011, 12:26 AM   #3 (permalink)
The Anti-RUB
petrock's Avatar
Originally Posted by NJ Rider View Post
Voldog;
Agreed... And even if you could turn the nipples, doing so when truing the wheel could break the seal and cause a leak.
The rubber strip on stock wheels will not seal the wheel properly. As the wheel spins, then rubber strip will stretch out due to centrifugal force and leak. So your tire pressure will be fine when stopped. But after a long ride your tire will slowly deflate.
Happened to a buddy of mine when we were on a 500+ mile ride. After around 150 miles his front wheel was 5 lbs low. Had to fill up to proper pressure at every gas stop. Pretty annoying for him and everyone else on the ride. At our destination, put a tube in the rim at a local shop and had no problems on the ride back.
Agreed... If not, they will be able to tell you where to go.
Personally, I wouldn't run tubeless on a spoked rim. Especially the front rim. Too hard to seal it properly and if you hit a pothole and dent the front rim you've got a blowout on your hands. I wouldn't be sitting here today if I didn't run a tube in my front rim. Hit a pothole at 75 mph about 4 years ago and dented the stock rim so bad I could touch the inner tube with my pinky once I stopped. If it wasn't for the tube, I would have gone down and who knows...
Vivid Black '06 FXSTBI
SE Stage-II 95"
My Two Front Teeph
Old 07-08-2011, 12:51 AM   #4 (permalink)
pigrider wants to know Dino or Syn?
If you want to run tubless tires buy a set of wheels that are designed for tubless tires, too much at risk in this area to be trying to design something of you're own. If memory serves me right several years ago Harley offered a laced wheel for tubeless tires, I very well could be wrong about this but it was short lived so don't know if they had problems with it or just wasn't a big seller.
pigrider is offline   Reply With Quote Quick reply to this message
Old 07-08-2011, 04:28 AM   #5 (permalink)
Swamprat Rider
JayFL459's Avatar
JayFL459 wants to know Dino or Syn?
Want Spokes Run Tubes with your tire ... Why the Spoke Wheel is gone now on the FXR ..
2005 Dyna Superglide/ 2012 Vic Cross Country Stage 2/ 2015 Indian Scout Stage 1
JayFL459 is offline   Reply With Quote Quick reply to this message
Old 07-08-2011, 07:27 AM   #6 (permalink)
59panhead wants to know Dino or Syn?
I agree with pigrider spoke wheels need to be trued....and I do mine evey time a tire comes off the rim if you add sealer to the rim after it throws off the balance if you turn the nipples after the rim is trued, you break the seal .....dumbest thing I have read on this forum yet ! other then Harley saying they dont have a over-heating problem or a cam tensioner problem !
whats the big deal about running a tube ? if it was a good IDEA.....Somebody would have done it by now!
I have been collecting Bikes 46 yrs had over 50 at one time .....got that # down to 14 now....not one mag wheel in the bunch......tubes and spokes rule!
59panhead is offline   Reply With Quote Quick reply to this message
Old 07-08-2011, 03:31 PM   #7 (permalink)
NJ Rider's Avatar
Petrock;
I wondered about putting a tube in a tubless (cast) rim on a motorcycle. A month or so ago I bought 9 spoke (stock wheel chromed) rims for my SG, and toyed with the idea of using a tube simply as an extra margin of safety. Guess I'm gonna do it now. With the expense of tires, rotors, bolts and such, what's another $35?
Old 07-08-2011, 03:50 PM   #8 (permalink)
FXDRYDR is reading this now saying WTF is this? FXDRYDR is reading this now saying WTF is this?
Why not just run a tube like they were designed for?
FXDRYDR
2003 FXD
124
Black, chrome & loud.
Old 07-11-2011, 08:54 AM   #9 (permalink)
I've been running tubeless on spoke rims since 2006, lot's of other folks have too. I've been using the fast cure 3m 5200, it works. I've yet to have a problem. I wasn't asking if I should use 5200, I was asking if there was anything better.
When I seal the spokes, I don't do it individually. I put a coating on the entire spoke area, from one side to the other. I make sure I get all the oil out of the wheel before I apply the coating. With the entire area sealed, and a spoke is turned, it is still sealed because the entire area is sealed. This process takes a little while and like I said can get messy but works very well.
I don't argue the point about high speed pot holes but that's true with any tubeless tire.
By the way, balancing is not a problem because I used dyna beads to balance the tire, stays in balance regardless of what's going on with the wheel. And no, the beads don't get stuck in the 5200, the 5200 is on the inner part of the wheel, the dyna beads on the outer.
Old 07-11-2011, 03:53 PM   #10 (permalink)
lastinclass wants to know Dino or Syn?
I've been running tubeless tires on both of my bikes for years. I tour by myself and was always worried about getting a flat in BFE. I did the procedure myself using instructions from another fellow who had put 40,000 miles on his with no problems.
I just now wrote up the complete instructions and when I went to submit it, I had evidently timed out. Too bad. I'm not about to do that again. If someone can tell me how to write a long submission without getting timed out...or another way of accomplishing that, I'll try again.
By the way, the product I used was Dow Corning Silicone II Aluminum and Metal formulation. Got it at Lowes. I think it's used for gutters and such.
lastinclass is offline   Reply With Quote Quick reply to this message
Old 07-11-2011, 04:00 PM   #11 (permalink)
Me again. The reason I wanted tubeless tires is that supposedly they tend to go flat at a slower rate than tube tires. The tube evidently tends to tear and deflate faster. And also, fixing a flat on the rear tire of a softail with a tube in the middle of western Texas on a nice warm August day is not my idea of a good time.
Old 07-12-2011, 08:37 AM   #12 (permalink)
Lastinclass, I sent you a pm.
Old 07-12-2011, 10:26 PM   #13 (permalink)
ESS
ESS wants to know Dino or Syn?
I usually do the write up in Word (or something similar) and then when I'm finished I'll copy and paste it in the reply section on the forum. Then submit!
ESS is offline   Reply With Quote Quick reply to this message
Old 07-14-2011, 08:14 PM   #14 (permalink)
O.K. I think I have this thing figured out. Below is a link to the instructions on how to seal wire (laced) wheels. I've done this on my springer classic and a metric scoot. Put touring miles on both bikes with no problems. Also have had no problems with balancing.
http://www.gadgetjq.com/tww.htm
Old 07-15-2011, 08:24 AM   #15 (permalink)
thanks for the write-up. I think I'll go that route instead of the 3m5200.
