Squeaking/Squealing : V-Twin Forum: Harley Davidson Forums
Old 05-28-2010, 08:47 AM   #1 (permalink)
Dill wants to know Dino or Syn?
Squeaking/Squealing
So after buying my fxr in Nov I finally got to really ride it yesterday, and now I have a problem. Well to start out with I think the bike is cursed. A tie down strap broke on the way home and the bike got all sorts of beat up between Syarcuse NY and my house in NH. Then I had it up at a buddy's shop this spring. After we got it all back together with a new tank etc, it got knocked over badly in the shop.
Banged up the tin again.
Anyway rode it home last night. And at first I heard a squeak from the front end when I rolled off the throttle. After 5 miles that turned into a constant squealing from the front end. Could this be an axle issue? There seems to be some vibes in the front end as well.
The bike has 14,900 miles on it, but I don't know any of the history other than a repo from NV and it has newer HD custom wheels.
1992 FXRS-C 2:1 Parker Pipes, S&S carb, FXE hard bags
1987 FXLR (Wife's bike) V&H staggered straight shots
Dill is offline   Reply With Quote Quick reply to this message
Old 05-28-2010, 03:27 PM   #2 (permalink)
LowRiderCustom wants to know Dino or Syn?
Check the wheel bearings and the brakes, it could be either one. If the bike has set for a while the grease in the wheel bearings probably got hard.
LowRiderCustom is offline   Reply With Quote Quick reply to this message
Old 05-28-2010, 06:31 PM   #3 (permalink)
60195 wants to know Dino or Syn?
Dill, process of elimination. If the noise is coming from the front end and only happens when the bike is moving, then it can only be the brakes or wheel bearings. An easy way to isolate it is to unbolt the front caliper and go for a short ride around the block.
Not really the school solution but it will work.
60195 is offline   Reply With Quote Quick reply to this message
