Originally Posted by il-rigido
Hi everybody.
I've noticed that if I get off hands from my 2008 FLHR handlebar at 40/45 MPH it tends slightly to the left.
Someone says it's normal with touring bikes (my Sporty runs stright), and someone else says I have to adjust rear wheel alignment.
What do you say???
And how have I to adjust it???
RR
Ciao RR!
I had the same on my 09 FLHR.
You´ll probably also notice that the handlebars seem to point a little to the right when you´re going in a straight line yes?
You need first to make sure the rear axle "snail" eccentric plates are nudged against the little shoulders on the swing-arm.
Loosen the axle nut and slacken the belt. Insert a feeler gauge (I used a 0.7mm) between the left side snail-plate and the little shoulder it normally rests against, and tighten the belt to spec.
While doing this, make sure the right side snail-plate rests against it´s shoulder; they have a habit of moving while you´re tightening everything; maybe the help of a second pair of hands is necessary; and tighten everything up. Make a note of which size feeler gauge you used, so if it´s still not right afterwards, you can make further adjustments if necessary. You´ll need these notes when your bike has been in the workshop, so you can do it again after the mechanic has been wrenchin on yer bike!
It took me a couple of times to get it right, but it´s fine now, and I can take my hands off the bars when using the cruise-control, and she goes straight as an arrow.
When you test ride, make sure you´re on a road that has no camber to it; must be dead flat.
Hope this helps
mike
