diovol-
Kindred spirits it appears. You will have to clue me in as this goes on as to how you overcame some of the hurdles.
As it happens I spent some more time today working out the fender issue. I had planned on just doing the minimum
(since it would never be seen) but after looking at it I really needed to do it the best way I could not the quickest/easiest.
So, based on the measurements taken off the bike, I needed to widen the fender at least 3/4". After measuring the nuts on the fender mounting bolts, which came to a smidge under 7/8"" I decided to take the fender out to eliminate those thick bolts.
Step one - Bifurcate the rear fender
With the rear fender split down the center line I cut a 1" strip from some 10ga. stock I had from building medieval armor and began the process of making the halves whole once more.
Once I had the bits tacked back into one I needed to take it back to the bike
(which is at Phoenix Customs where they are machining the front wheel) and do a test fit before I went any further. The fitting went really well so its on to finishing the welding; which includes filling any hole from the stock accessories/tail light etc. Since this is going to be the "under fender" for the 'glass finish fender, it doesn't have to be pretty, just solid. I need to remove the added 1/2" from the belt clearance on the left but other than that, no other issues noted.
For those who would consider this on a stock bike, the fender widening would be a much more detailed issue to get right. Details like drilling out the spot welds in the tail light backer and removing it before welding the halves then replacing it back in the center and filling the 1/2" to each side for a stock look and mounting.
