Originally Posted by trooper113
If you're having "tank slaps" at all, you have major problems that are most likely not tire problems.
I'd second that, I'd guess at a chassis problem for tank slappers, but I noted you said that the problem appears '[i]when I first start out'[i]-does that mean it goes away?.
You said the front end shakes, but are the bars moving left right in your hands?.
I'd go to a shop so a mechanic can see-feel the problem.Some dealerships can be a bit limited if a problem is outside the digitech system. If so, has your PD/Sheriffs dept got a motorcycle unit? try asking the mechs in their motorpool shop (thats if they have one nowadays since some beancounting dork came up with outsourcing/contracting).Good luck.
