American Side Road CycleSportbikeTrackGearJardineProducts.comBikeBanditProCharger.comBub EnterprisesDiamond Bar Choppers
Old 09-28-2009, 06:24 PM   #1 (permalink)
ltrclwn is on a distinguished road
Question help with adjusting progressive 440's
i tried a search for this but came up empty..
i just installed the progressive 440's 11.5 on my 08 street glide...
my question is how do i adjust these...every time i turn the top collar the bottom collar also turns with it....i have tried holding the bottom collar when turning also....
also how do i know it is adjusting, as i am not seeing the register marks to match up the dimples to the shock body????
i went with the 11.5 because i needed to get .5" lower to ground to be flat footed when stopped....with air i was tippie toe'd...i also changed the seat when i first got the bike to lower me, and even after the seat has broken in still was not enough drop....
any help would be greatly appreciated....
thank you in advance,
matt
ltrclwn is offline   Reply With Quote
Old 09-28-2009, 07:55 PM   #2 (permalink)
Formerly 04GLIDE
03GLIDE_'s Avatar
Twist the top collar full turns at a time. After about 3 or 4 turns you should start to see the register marks. It does not matter if the bottom collar turns. the top one does the adjusting as it pushes the spring farther away from the top shock mount. I think 11 turn is the range of adjustment if my CRS isn't corrupting my thoughts.
EDIT: Make sure and do them both the same.
Old 09-28-2009, 08:01 PM   #3 (permalink)
Should I grip the spring whil turning the collar or use both hands on the top collar
Old 09-28-2009, 08:30 PM   #4 (permalink)
both hands on the top collar. it does not matter that the spring is turning that is normal. I put a mark on one of the indentations in the top collar with a marking pen and then I can keep track of how many turns I have gone from fully soft.
Mtclassic is online now   Reply With Quote
Old 09-28-2009, 10:38 PM   #5 (permalink)
POPS87FXR's Avatar
POPS87FXR is on a distinguished road
Didn't a set of instructions come with the shocks?
How do you want it? Fast, Perfect, Cheap......Pick 2
POPS87FXR is offline   Reply With Quote
Old 09-28-2009, 10:48 PM   #6 (permalink)
IT did. The instructions are basic of basic. They did not explain how to adjust just counterclockwise for softer clockwise for stiffer. Nor did they distinguish the makers to look for just says match dimples up to marks on shock body. And make sure both sides the same.
Old 10-02-2009, 08:15 PM   #7 (permalink)
Indianspringsaz is on a distinguished road
I am at 6 full turns and runs great 2 up and solo. I go 245 and she is 118.
07 Road King Standard
GMR 107 with Andrews 54 cams
D&D Fat Cat
Big Sucker
SERT 107/115
Neighborhood Amsiol Dealer
Indianspringsaz is offline   Reply With Quote
Old 10-05-2009, 08:51 AM   #8 (permalink)
Zipped06's Avatar
Zipped06 is on a distinguished road
Good luck with them. I have the same shocks(11.5") on my bike. I'm up to the third adjustment mark, and they still bottom out when I hit a pot hole. I'm 215# and have the HD springs. I can't ride two-up with them. Not enough travel for a touring bike. I'm going back to the 13" length 440's.
2006 FLRTI, Zippers 95" Muscle Kit w/Gear Drive, Thundermax w/Auto-Tune, D&D Fat Cat, Baker OD6, 95 HP/93 TQ
Zipped06 is offline   Reply With Quote
