SportbikeTrackGearAmerican Side Road CycleLeslie Kay'sMotorcycle.com Classifieds!Motorcycle-CommunicationCustom DynamicsAdvanstarMotorcycleShowsBub Enterprises
JekillandHyde.eu
Old 09-20-2009, 05:42 PM   #1 (permalink)
dwayneiac2 is on a distinguished road
Need help installing air ride!
Trying to install arnott air ride suspension and here is the problem.
I first tried hooking it up by itself to the battery and it works just fine.
After the negative post is hooked back up to the battery, the air ride will inflate but when trying to lower the bike the fuse will blow.
Anybody got a clue!!
dwayneiac2 is offline   Reply With Quote
Old 09-20-2009, 08:03 PM   #2 (permalink)
wildbillnc
WILDBILLNC's Avatar
WILDBILLNC is on a distinguished road
Sounds like you have the valve wired wrong
2003 Electra Glide Clasic
95" Se flat top pistons
Hillside Cycle Stage Three Heads
SE Adjustable Push Rods
Wood TW6G Cams
D&D Fatcat 2 into 1
103HP
106 Torq.
WILDBILLNC is offline   Reply With Quote
Old 09-21-2009, 12:26 AM   #3 (permalink)
I'm Paid Up...
Check the wire that runs the down circiut. If you are blowing fuses, you are pulling too much current......so I'd check the wiring to verify you do not have a wire touching the motor or the frame(ground).
DR_DEUCE is offline   Reply With Quote
Old 10-05-2009, 05:11 AM   #4 (permalink)
Well fellas, havnt had much time to work on the bike, but I finally got some time off and this is what I found. After installing the upgrade hadlebar switch to raise and lower the shocks, I ran the wires out of the handlebars and under the gas tank. Problem was, I have the chrome neck cover on my 07 rkc and after reinstalling it while running my wires from the handlebars, looks like I pinched the wires and it was shorting out. Taped all wires up and was a little more careful replacing the neck cover this time and its working great. Ill tell ya... its pretty nice to be able to adjust for a better ride on the fly. Next project...I think I want a 117...I cant help it. I got the 103 with 255 cam for now and after riding it to the National Round up in Georgia from houston tx., the cam is broken in good (if there is such a thing) and it sounds great.
But you guys are killing me with the videos of the 117's.
Damn they sound good!!!!!!!!
