Motorcycle.com Classifieds!AdvanstarMotorcycleShowsPro PadCustom DynamicsProCharger.comMotorcycle-CommunicationBikeBanditRRcycles.comMotorcycle.comDan Vance RacingDiamond Bar Choppers
Pro Pad
Old 09-15-2009, 09:41 PM   #1 (permalink)
Courtright11 is on a distinguished road
STILL no front brake!
I have a 99 Softail FXST Standard.
I replaced the Front Brake Hose, rebuilt the MC Assembly, replaced the MC Cover and rubber gaskets, rebuilt the Caliper Piston, installed a new Rotor + Pads and lastly added Speed Bleeders (which I thought would help with the bleed).
And I still have NO front brake pressure.
Any thoughts?
Courtright11 is offline   Reply With Quote
Old 09-15-2009, 09:51 PM   #2 (permalink)
I'm Your Huckleberry
Mr Cujo's Avatar
Mr Cujo is on a distinguished road
more bleeding required..or you are still bypassing somewhere
The Fair Tax- (go ahead, click it.)--
'07 Ultra -> Covington, Ga.
Mr Cujo is offline   Reply With Quote
Old 09-16-2009, 12:12 AM   #3 (permalink)
Front brakes are a real pain, any air at all they wont have any brake you probably have air in the system. With mc cover off look at the fluid very carefully squeeze brake lever if you see any bubbles at all you have air in the system,you can squeeze lever (just a little) again and again until you see no bubbles ,then you should have some brake and can start blleeding them. In the past I have done this for allmost an hour until I have some brake. HD reccomends with the instructions that come with extension kits that you remove mc cover fill fluid level then take a bungee cord squeeze lever all the way, overnight all the bubbles will slowly seep out of the system,be sure and put a rag over the mc so no dirt gets in it...good luck tom..
Old 09-16-2009, 02:36 AM   #4 (permalink)
F$ck Google ads
ViennaHog's Avatar
remove the caliper and turn it with the bleed screw up (bungee cord comes in handy) and bleed again. During bleeding tap the mc fluid reservoir gently with a screw drives. Helps to free up air bubbles. Texas Tom gave another alternative which should work.
2008 Ultra dark blue pearl
BigBoyz ported street heads
103" SE FT
0.030 Cometic HG
Woods TW 6
V&H Monster Ovals
SE ventilator a/c
TTS
SE compensator
SE race clutch
VPC 92 T
Magura hydraulic clutch
BaggerBrace stabilizer
Full floater front discs
After Douglas Adams RIP
ViennaHog is offline   Reply With Quote
Old 09-16-2009, 08:10 AM   #5 (permalink)
The Anti-RUB
petrock's Avatar
Make sure the caliper is lower then the reservoir when you do this. Easy with the front brake, but can be tricky sometimes with the rear brake.
Make sure you tap with the plastic end of the screw driver, not the metal end. Don't want to ding/scratch/damage anything. I would also tap more then just the reservoir. I would start tapping the caliper, moving on up the brake line and then the reservoir. Do it each time you close the bleeder screw.
During the bleeding process, I also like to squeeze the brake lever a bunch of times to help build up some pressure in the line, and then hold it compressed while I crack/burp the bleeder screw. The extra pressure in the line helps force the fluid (and any bubbles) through. Good luck...
Vivid Black '06 FXSTBI
SE Stage-II 95"
My Two Front Teeph
Old 10-07-2009, 09:03 AM   #6 (permalink)
deuce163 is on a distinguished road
I know it sounds silly, but rolling the bike back a few feet works for me. I just don't know why...
deuce163 is offline   Reply With Quote
Old 10-08-2009, 07:35 AM   #7 (permalink)
BOUTYM's Avatar
BOUTYM is on a distinguished road
Had this happen when I was changing to aftermarket chrome controls. Drove me nuts and eventually figured it had to be bypassing in the MC somehow. Got tired of messing with it and sent the whole mess back and bought HD controls. Sure enough the place where I bought the problem MC found it was bypassing internally and tested a handful of the others they had in stock and they were doing it too. Don't recall the brand, but it was one of those E-Bay trying to save a few bucks things.
If you pick up a starving dog and make him prosperous, he will not bite you; that is the principal difference between a dog and a man. - Mark Twain
Paddle Faster... I Hear Banjos
BOUTYM is offline   Reply With Quote
