Tire Pressure Question : V-Twin Forum: Harley Davidson Forums
Old 05-25-2009, 09:30 PM   #1 (permalink)
Dipsy is on a distinguished road
Brought home a new 09 Dyna Low Rider and after everything cooled off I was going over the owner's manual and checking things out. I checked tire pressures and the front tire had 36 psi. The manual called for 30 psi front and 36 psi rear for solo rider. I lowered the front to 30. Took the bike in for 1K service and when I got home I noticed the work order showed front was back at 36 psi. The owner's manual shows 36 for the FXDF but not the FXDL. Does the service tech/department know something that I don't or is there a reason they have twice set the tire to 36 psi?
Dipsy is offline   Reply With Quote
Old 05-25-2009, 10:35 PM   #2 (permalink)
Shoe's Avatar
Shoe is on a distinguished road
My guess is that they are wrong and inadvertently overinflating them. If you are going to get the dealer to do the servicing, I would just ask them about it next time.
Dave
2008 FLHRC
Rinehart True Dual Exhaust System
Arlen Ness Big Sucker Intake
Super SERT Dyno Tune by HD of Montgomery, AL
Shoe is offline   Reply With Quote
Old 05-26-2009, 07:38 AM   #3 (permalink)
bagga's Avatar
bagga is on a distinguished road
i don't go by what the book says, i put the air pressure at what it says it should be on the side of the tire.
bagga is online now   Reply With Quote
Old 05-26-2009, 09:00 AM   #4 (permalink)
honorsdaddy's Avatar
honorsdaddy is on a distinguished road
Tire pressure is determined by the weight of the vehicle, not by what is on the side of the tire.
Tires are designed to fit multiple vehicles of differing weights. What is on the side of the tire is the maximum safe pressure for that tire - typically this is much higher than what is required for the vehicle on which it is installed.
By running a pressure which is too high, you lose ride quality, increase your braking distance, and shorten your tire life. You also increase your risk of losing traction on wet roads. You may gain a marginal increase in fuel mileage, but not enough to to offset the risks above. The vehicle may appear to handle better as it sometimes responds more rapidly to steering input, but in reality, as the tire contact patch is smaller than it should be, its actually handling worse.
With all that being said, it is not uncommon for an OE tire to be stamped with a "max" tire pressure which corresponds to the proper pressure for the vehicle. Do not rely upon this though.
In short, the tire load information sticker on the vehicle is the final authority on what is proper for any given tire size and load. When you change from stock sizes things change, but there are charts to calculate this.
Ok - education mode off...
honorsdaddy is offline   Reply With Quote
Old 05-26-2009, 09:32 AM   #5 (permalink)
Prog Rocker's Avatar
Location: "Close to the edge, round by the corner...Close to the edge, down by a river...Seasons will pass you by, I get up I get down..."
Prog Rocker is on a distinguished road
Exclamation
You didn't mention whose tires are on the bike.
Unless they are OE-spec Dunlops, it is best to check with the tire manufacturer and see what their actual recommendations are. Quite often they are higher than the stock Dunlops.
All tire pressure specs are based upon a COLD reading, meaning the tire is at rest and has been so for at least two to three hours. The best (and easiest) time to check is in the morning before starting to ride, when the tires have been at rest overnight.
The primary consideration for motorcycle tire inflation is LOAD.
Overinflation and underinflation can have various negative side effects on either/or the tire(s), the motorcycle, or YOU...some of which have already been mentioned.
Cheers
"I have a plan so cunning, you could put a tail on it and call it a weasel...!" - Edmund Blackadder
Prog Rocker is offline   Reply With Quote
Old 05-26-2009, 09:35 AM   #6 (permalink)
Faast Ed is an unknown quantity at this point
Numbers on the side of the tire are MAXIMUM pressure.
But I have to admit, 30lb sounds awfully low to me and 36 sounds more sensible.
Also, whatever number you settle on, should be check while the tire is cold, not after a ride on a hot day.
Faast Ed is offline   Reply With Quote
Old 05-26-2009, 10:20 AM   #7 (permalink)
Fourcats's Avatar
Fourcats is on a distinguished road
The good thing is you were checking it
I run 36+ front and rear on the Low Rider and the Road King and the Sportster. Found the tires were all down {22-25} from sitting over the winter.
Fourcats is offline   Reply With Quote
Old 05-26-2009, 01:26 PM   #8 (permalink)
fafcpa is on a distinguished road
My '08 Street Bob manual says 30/36 front back. Don't even know what the tires say. Hopefully my tire gauge is accurate when I check them and adjust the pressure.
Fred
fafcpa is offline   Reply With Quote
Old 05-26-2009, 06:40 PM   #9 (permalink)
Thanks for the input everyone. Tires are the OEM Dunlop D401F. When I put new tires on my Z car the tire shop recommended a higher pressure than the sticker on the car. I wondered if maybe the techs at the Harley dealer had raised the front tire pressure based on their experience working on bikes. I'll ask when I take the bike in to get the forks checked next week. I normally check tire pressure at least once a week in the morning or before heading out for a ride.
Old 05-26-2009, 08:23 PM   #10 (permalink)
atrick is on a distinguished road
If you know someone with nitrogen, fill your tire with it because it dosen't expand when heated and you'll get a better ride, a better handling bike and longer tire life and when ever you check tire pressure hot or cold it will be the same reading.
atrick is offline   Reply With Quote
Old 05-26-2009, 09:27 PM   #11 (permalink)
NHFree1's Avatar
NHFree1 is on a distinguished road
N2 will expand, just not as much as regular air. Any difference will be negligible in a motorcycle tire. Some racers use it but unless there is significant heat generated in the tire such as in high performance racing where the tires are constantly breaking traction and generating heat through friction, if you're using N2, you're just wasting money.
"To sit back hoping that someday, some way, someone will make things right is to go on feeding the crocodile, hoping he will eat you last - but eat you he will." – Ronald Reagan
NHFree1 is offline   Reply With Quote
Old 05-26-2009, 09:51 PM   #12 (permalink)
Shoe's Avatar
Filling your tires with nitrogen is just a money making scam..... Unfortunately
2008 FLHRC
Old 05-27-2009, 12:02 AM   #13 (permalink)
semi-retired
FatBobRob's Avatar
FatBobRob is on a distinguished road
My 01 came with 30psi as stock,also. 36 is way high.Try 32psi,good compromise between ride/handling
I can't means I won't!
FatBobRob is offline   Reply With Quote
Old 05-27-2009, 12:12 AM   #14 (permalink)
semi-retired
FatBobRob's Avatar
Fred
You might wanna look at this: www.mcnews.com/mcn/technical/200511gauges.pdf
Old 05-27-2009, 05:39 PM   #15 (permalink)
sgott is on a distinguished road
Check the Metzler site
I have Metzler ME880's on my 2005 Wide Glide, and Metzler reccomends 36/40. Higher than the manual's reccomendation.
2005 FXDWGI, 2008 BMW 528i
Lawrence, NY
sgott is offline   Reply With Quote
