MU85-16 instead of MT90-16 on my Dresser : V-Twin Forum: Harley Davidson Forums
Old 05-21-2009, 08:48 AM   #1 (permalink)
ttgoddard wants to know Dino or Syn?
I own a 1999 Ultra Classic that is in need of a new rear tire. It currently has the std. size MT90-16, however, I wanted to know if anyone had replaced theirs with the slightly wider MU85-16?
The 85 has an increased load carrying capacity as well as slightly deeper tread for longer wear.
My only concern is the amount of clearance in the rear fender when loaded up with me and the misses .
The additional cost is small compared with the perceived benefits.
Thanks,
Tony
ttgoddard is offline   Reply With Quote Quick reply to this message
Old 05-21-2009, 09:11 AM   #2 (permalink)
Discarded Crew Member
ktwillys's Avatar
ktwillys wants to know Dino or Syn?
If I rememer correctly the MT-90 is the 130-90-16 tyre..and the
MU-85 is the 140-85-16 tyre...
you have not gotten much wider and a slightly lower profile (sidewall) and it should fit well.
I run the 150-80-16 on mine and it fits snuggly but with plenty of clearance even two up...
go for it..
To be old and wise,
Here's to old and stupid....
Orthopedic Motto
DisCarded Crew
04 FLTRI
SE Welded/Balanced Flywheel
103 CI
CP Hi-Comp Pistons
Andrews 54G Gear Drive Cams
S&S Hi-Lift Valve Springs
Timken Conversion
Baisley SuperSTock Heads
V&H True Dual Headers
Bassani Slip-on Mufflers
T-Max Ignition System
Feuling Oil Pump
Custom Feuling Cam Plate
ktwillys is offline   Reply With Quote Quick reply to this message
Old 05-21-2009, 10:26 AM   #3 (permalink)
Thank you, that was my feeling too that it should fit okay. Diameter is the same and width is only 0.3" wider according to the Dunlop web site spec.
Tony
1999 - HD Ultra Classic
1994 - HD Dyna Low Rider (wifes)
2001 - Quantum Liberty Cruiser Custom
