Custom DynamicsDiamond Bar ChoppersFuel MotoBikeBanditSportbikeTrackGear
Old 07-28-2008, 08:17 AM   #1 (permalink)
harveydean is on a distinguished road
Platinum Air Suspension
Is anyone riding on these? Problems. Likes. Dislikes
harveydean is offline   Reply With Quote
Old 07-28-2008, 10:12 AM   #2 (permalink)
R1Geezrglide's Avatar
R1Geezrglide is on a distinguished road
I've got them on mine-were on there when I bought the bike. The adjustability is great. However, you only have about an inch or so of actual shock travel wherever you are in the riding range. Things are pretty smooth as long as you're in that range, but once you have used that up, the rebound will toss you off the seat. They simply don't have the range of motion an air-spring shock like the Progressive 416 and Arnott offer. I've considered looking for a remote reservoir to effectively increase the chamber size and therefore increase functional travel. More likely, I'll just replace them with something else. They are great if posing at the local watering hole is your thing. Actual riding, touring and especially rougher or uneven road surfaces will leave you feeling beat up.
R1Geezrglide is offline   Reply With Quote
Old 07-28-2008, 03:45 PM   #3 (permalink)
On your set can you adjust the rebound? Bleed and Feed?
Old 07-28-2008, 03:51 PM   #4 (permalink)
Let er rip!
oh1deuce's Avatar
oh1deuce is on a distinguished road
I read that the Arnott only has 1" of travel on the softail set up.
R&R St. V cast heads
R&R 615/585's
R&R Cam plate
R&R Roller Rockers
oh1deuce is offline   Reply With Quote
Old 07-28-2008, 04:46 PM   #5 (permalink)
13MM is on a distinguished road
I have Platinum on soft tail.
Ride is great. Can adjust up, down & firmness.
Not sure about the 1 inch comment.
Eliminated the pogo feeling going over bumps.
13MM is offline   Reply With Quote
Old 07-28-2008, 05:42 PM   #6 (permalink)
I think maybe geezerglide has the older type that can only feed. Don't know. I have the bleed/feed and have no complaints. A little slow on the pump up, but I can firm it up for solo curves or soften it with two up and control the rebound.
Old 07-28-2008, 06:36 PM   #7 (permalink)
Tx_Outlaw's Avatar
Tx_Outlaw is on a distinguished road
I've had my set-up for over 2 years and love it! I also have the bleed/feed system on an '06 Train. Don't think I'd ever go back to regular shocks after this.
Chuck
'o6 FXSTBI
Slightly Modified......
Tx_Outlaw is offline   Reply With Quote
Old 07-28-2008, 06:45 PM   #8 (permalink)
Let er rip!
oh1deuce's Avatar
Where did you cats toss the compressor?
R&R 615/585's
R&R Cam plate
R&R Roller Rockers
Old 07-28-2008, 07:07 PM   #9 (permalink)
mooooving out!
route66paul's Avatar
The best part about this setup is that the firmness can be adjusted at any height. The problem that I have seen with these setups is that there are a lot of connections and sooner or later on will fail, it always seems to be one that is virtually unreachable.
43%er
Bi-polar and loving it!!
Bi-polar and hating it!!
95" w/ KB pistons (flattops)
HQ575 cams
Atwood's Road Warrior Heads
HPI bored throttle body
.030 head gasket
SuperTrapp Supermeg 2in1
"43" points cover
TRW rear mount
obligatory Baisley Spring
Just sayin..........
Old 07-28-2008, 08:23 PM   #10 (permalink)
Mounting
I mounted my compressor under the tranny. I got the bracket for the California canister and it fit nicely. If a fitting or tube goes bad, you only need to jack it up or remove the inner fender. The chrome one that comes with the kit is a pain but if I recall, Tex Outlaw used his stockone and mounted the valve assy. to it.
Old 07-28-2008, 11:07 PM   #11 (permalink)
Apparently only the softail application has the 'bleed and feed'. Mine simply pumps up and you get what you get-more air=more height.
Old 07-29-2008, 07:50 PM   #12 (permalink)
Tx_Outlaw's Avatar
Wasn't me with the stock splash guard. When I bought my kit, they only made everything chrome and stainless. I called the owner (Oscar at that time) and asked him to have everything powdercoated black for my Train. He sent my kit a few weeks later. I thought I had something dead on my system one time, but it ended up being a broken ground connection.
BTW: my compressor is mounted (hose clamped) at the top of the trans.
Chuck
'o6 FXSTBI
Old 07-29-2008, 09:04 PM   #13 (permalink)
Let er rip!
oh1deuce's Avatar
I think I'm going give them a try.
Who has the best price?
R&R 615/585's
R&R Cam plate
R&R Roller Rockers
