Diamond Bar ChoppersPowerstar SparkplugsFuel MotoDan Vance RacingCustom DynamicsOriginal Bike SpiritsStainless Ride Specialty Accessories
GoFreeCreditReport
Old 03-24-2003, 07:59 PM   #1 (permalink)
ksnowdale
heavier oil for lowered forks
I recently installed an Arlen Ness lowering kit on my 99' Fatboy, with shortened dampener rods in the front forks making use of the stock springs.
I haven't bottomed out yet, but there is a little "clunk" on the rebound at times, especially on smaller bumps. I'm thinking of moving to a higher viscosity of fork oil. I'm running HD's Type E right now. Can anyone reccommend which brand/type of fork oil I should move up to?
ksnowdale is offline   Reply With Quote
Old 03-24-2003, 08:18 PM   #2 (permalink)
FOG
trooper113's Avatar
trooper113 is on a distinguished road
Screaming Eagle Heavy worked well in my '03 FXD to fix excessive compression/rebound.
trooper113 is offline   Reply With Quote
Old 03-28-2003, 07:25 AM   #3 (permalink)
jrrhdmust
One of the issues in Hot Rod Bikes last year did an oil comparison, where the checked some of the diffent weight oils in a stock front suspension. I am pretty sure their recommendation was to use 1/3 the heavier weight and 2/3 stock oil. This firmed up the suspension a little, but not too rough of a ride.
I thought I scanned in the article, I will try and find it.
"Whoever said the pen is mightier than the sword obviously never encountered automatic weapons." -Gen. Douglass Macarthur
jrrhdmust is offline   Reply With Quote
Old 03-28-2003, 11:24 AM   #4 (permalink)
ksnowdale
Cool
Thanks to both of you. I went with the Screaming Eagle heavy, and took it for a test ride. That did the trick. The problem was rebound clunk on small bumps at low speeds. The SE heavy took care of that. Less of a shock all around.
I recommend anyone installing the Ness Lowering kit's front shortened dampener rods (full 2" lower) to go with SE's heavy fork oil.
Now to see how they perform on a long trip. Off to LA next weekend!
Old 03-28-2003, 12:24 PM   #5 (permalink)
FOG
trooper113's Avatar
Glad it worked for you. SE Heavy oil and 1" spacers did wonders for my FXD forks. When I get around to it, I'll take out the spacers and put in Progressive springs.
